Author Topic: Removing the 'beep beep' in my central locking  (Read 2167 times)
Offline Madmax
« on: 15 August 2009, 10:39 »
Hi,
My central locking has a very loud 'beep' noise when i lock/unlock, where may i be able to find the part that
handles the beeping & when i find it, is it just a case of unplugging the wires?
Thanks.
Re: Removing the 'beep beep' in my central locking
« Reply #1 on: 15 August 2009, 10:41 »
Well it is not factory and sounds like something has been added, find the unit and cut the wire.
Offline Madmax
« Reply #2 on: 15 August 2009, 10:42 »
« Last Edit: 15 August 2009, 10:44 by Madmax »
« Reply #3 on: 15 August 2009, 10:43 »
Will it just look like this: http://www.autoectech.com/auto%20accessories/car%20horn/horn.jpg
Unplug it and if the central locking looking still works leave it be.
Offline Madmax
« Reply #4 on: 15 August 2009, 10:44 »
Ok, will have a look. Cheers.
« Reply #5 on: 15 August 2009, 10:45 »
No worries
Offline Madmax
« Reply #6 on: 15 August 2009, 12:40 »
Ok, so located the beeping which was coming from under the bonnet & i think it's the bell shaped object in the photo below.
It has 2 wires coming from it, what now? if i disconnect it, wont they disable the alarm too?
« Reply #7 on: 15 August 2009, 13:31 »
Well that alarm is not factory, yes if you disconnect it then it might not work but it is the only way to stop it beeping.
Offline Madmax
« Reply #8 on: 15 August 2009, 13:45 »
Guess i'll be sticking with it then. it's not /that/ bad i guess.
Offline match
« Reply #9 on: 15 August 2009, 14:07 »
The beeping is the alarm arming itself 2 beeps armed 1 beep disarmed,no beeps no alarm my clifford alarm did it on my scoob at least you know it works!But on mine you can adjust the loudness of alarm and sensitivity in the alarm box/bell its a little volume switch.
