Author Topic: Rocker Cover gasket changing  (Read 1457 times)
Offline Jay
  • balding fat cvnt
« on: 14 August 2009, 21:44 »
This will be the first time I'm opening the engine up and I'm worried I'll screw something up, and if I do I'm in the sh!t because it's my daily.
Am I just being a pussy/worry wart or is it really that simple to change a rocker cover gasket on the GTD's?  :undecided:
I don't need any gasket sealant do I?
Will I only need the gasket and nawt else?
gtigolfthree
Re: Rocker Cover gasket changing
« Reply #1 on: 14 August 2009, 22:19 »
As long as you dont damage the gasket should be ok. Why you changing it you got a leak?
« Reply #2 on: 15 August 2009, 00:15 »
Easy to do.
Offline Jay
  • balding fat cvnt
« Reply #3 on: 15 August 2009, 11:13 »
Yarp, oil coming out of the top of the head between the rocker cover and head. It's more of a seep and I don't loose *that* much oil considering it's also a diesel.
If this delivery ever comes I'll be heading to GSF and picking up a few gaskets, just to be safe.
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 15 August 2009, 15:57 »
just make sure you put it on properly.
*****MK3 Anniversary*****
*****MK4 GTI T*****
