Author Topic: JVC head unit won't fit all the way in :(  (Read 2241 times)
Offline Mr.Tom
« on: 14 August 2009, 00:34 »
I was trying to fit my JVC KD-AVX2 head unit into the Mk3 GTi, but there are a few too many wires on the back of the unit that seem to be jamming up at the back and stopping the unit from sitting flush.
Is the plastic in the back of the bay anything important, or could I cut it away to make room? It's rather frustrating, as I am currently stuck with a badly battered Sony that came with the car and skips every few seconds :/
Offline troublestarter
Re: JVC head unit won't fit all the way in :(
« Reply #1 on: 14 August 2009, 05:23 »
just remove the glovebox
you can then pull all the cables over to one side to allow the unit to fit nicely
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline dirtydub
« Reply #2 on: 14 August 2009, 12:08 »
I sometimes tie some string or somethin around the wires and feed it through a gap in the dash. Then pull the string as u slide the headunit in place  :wink:
Rich
'86 golf gti 8v k-jet project up and running :)
Offline Mr.Tom
« Reply #3 on: 14 August 2009, 22:24 »
Cheers. Tried removing the glove box in the end. Is still a bit tight, and not entirely sure I can get it out again if I need to. But it kinda works, although loses power whenever the ignition is off. Will work out where to get some power from in the morning :)
« Reply #4 on: 17 August 2009, 09:27 »
you need to sway the red and yellow round on the jvc loom that will solve that problem
Offline Mr.Tom
« Reply #5 on: 04 September 2009, 21:20 »
Yeah, I found the little box at the bottom of the instructions tha tsaid I had to swap some wires :D Cheers tho.
