Author Topic: Different head  (Read 4832 times)
Re: Different head
« Reply #1 on: 12 August 2009, 09:13 »
link jusat goes to cylinder head section on ebay?
gtigolfthree
Re: Different head
« Reply #2 on: 12 August 2009, 09:31 »
Yes 325 items :laugh:
Re: Different head
« Reply #4 on: 12 August 2009, 12:19 »
it'll fit, you'll need to swap the injector inserts for k-jet ones, depending on the age of your head the old ones may not fit, so you'll have to source later ones. 16v items should fit
Offline danny_p
Re: Different head
« Reply #5 on: 12 August 2009, 13:57 »
is DX not a solid tappet block, threfor missing the oil return gallery for a hydralic tappet head ?
all the VW's have gone bar 1.
Re: Different head
« Reply #6 on: 12 August 2009, 14:39 »
i was under the impression the blocks were the same regardless of solid or hydro?  if not then yeah the dx is probably a solid lifter one unless its very late
Offline danny_p
Re: Different head
« Reply #7 on: 12 August 2009, 14:56 »
i thought when vw changed to hydralic tappets they added an extra return gallery the sump.  i know a solid lifter head can go on a hydralic tappet block  but not sure about the other way round,  proably will just on of the return pots may need plugging,  just somethign that may be worth checking
Re: Different head
« Reply #8 on: 12 August 2009, 17:22 »
I am sure your right and it will need plugging.
Offline larky75
Re: Different head
« Reply #9 on: 13 August 2009, 07:55 »
Right thanks for all that advice. It sounds like it will go on with the help of a good garage I recon I'll go for it
