Author Topic: Different head  (Read 4834 times)
Re: Different head
« Reply #10 on: 03 September 2009, 16:44 »
right well its taken this long but I've eventually found a picture of a solid lifter head from underneath, and its the same as a hydro lifter head :)
hydro lifter head:
http://vwtech.no-ip.info/images/golf/8vhydrolifter.jpg
solid lifter head:
http://vwtech.no-ip.info/images/golf/8vsolidlifter.jpg
unless the early/late solid lifter head differ? :undecided:
Offline diver705
Re: Different head
« Reply #11 on: 10 September 2009, 11:42 »
Can anybody tel me if bore out my 2.0 8v head will car pass mot after. :undecided:
Offline danny_p
Re: Different head
« Reply #12 on: 10 September 2009, 12:54 »
hydro lifter head:
solid lifter head:
will go on a quest to find  but i'm sure there is a pritty magor change at some point
all the VW's have gone bar 1.
Re: Different head
« Reply #13 on: 10 September 2009, 13:40 »
maybe its the MK1 1.6 GTI lump -> 1.8 GTI lump where this changed?
Offline danny_p
Re: Different head
« Reply #14 on: 11 September 2009, 01:05 »
i recon 08/1982    may be when it happend.
Offline bored_Welsh_lad
Re: Different head
« Reply #15 on: 12 September 2009, 07:58 »
when you say "bore out the head" are you on about polish and porting the head or increasing the cylinder capacity of the block??
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline danny_p
Re: Different head
« Reply #16 on: 12 September 2009, 22:02 »
a 1.8 head will go straight onto a 2.0 block.  you do not have to change anything,    it is however adviasable to place the 2.0 gasket over the 1.8 head and trim the edge of the combustion chamber out to the gasket.
some enigne need it some don't  but there is potential for  the edge of upto .75mm sticking out,  managable but not optimal
Offline diver705
Re: Different head
« Reply #17 on: 17 September 2009, 15:09 »
seriously thinking of putting 1.8 20v turbo head on my 8v bottom end. What you think :laugh:
Re: Different head
« Reply #18 on: 17 September 2009, 15:21 »
Don't think it will fit or very well to be honest.
Offline diver705
Re: Different head
« Reply #19 on: 17 September 2009, 15:26 »
ow, was told it would. Will take your advice on this 1 :wink:
