Author Topic: Problem cold start????  (Read 1429 times)
Offline glasby82
« on: 11 August 2009, 12:11 »
Hi all this new to me. Any help is much appreciated.
 I have a mk4 1.8 gti 20v,
The prblem is on cold start takes a very long time to fire and sounds quite rough, Once running and warmed up she's fine. Slight rattle on top end when running also.
Thanks.
gtigolfthree
Re: Problem cold start????
« Reply #1 on: 11 August 2009, 13:24 »
Hi welcome to the site, how long have you had the car, when was it last serviced?
Offline glasby82
« Reply #2 on: 11 August 2009, 18:47 »
Hi ive had the car 2 days and not sure on last service.
When starting the oil light does flash with a beep but goes off when started.??????
gtigolfthree
« Reply #3 on: 11 August 2009, 18:56 »
Yes I would start by giving it a good service plugs, air filter oil and filter etc.
Offline glasby82
« Reply #4 on: 11 August 2009, 19:01 »
That is on cards just wondered if was a simple solution or not, Checked all other posts and they all lead to a coil pack......Is this just leads plugs etc???
gtigolfthree
« Reply #5 on: 11 August 2009, 19:18 »
post your question in the mk4 section and you will get more help
