Author Topic: car stalling  (Read 1605 times)
Offline the beast
car stalling
« on: 04 September 2004, 17:28 »
can someone tell me why my car drops revs :o then stalls when started or when you dip the clutch ??? but runs ok after about 2 mins running? ? ;D the beast is a 2.0 gti 8v mk3 1996 runs at 800revs on tick over
Rain
Re: car stalling
« Reply #1 on: 04 September 2004, 17:33 »
dropping the clutch? that mean your in gear or you mean dropping it to engage a gear?
Offline Neilos
Re: car stalling
« Reply #2 on: 06 September 2004, 19:01 »
I had the same problem with a 1.6 mk3 I used to have, when you approach a junction or just put the clutch down the revs would drop and usually catch themselves again (if engine was warm), however when cold it would stall.
I spent loads trying to get it sorted, had a new map sensor, new ECU, but still didn't solve the problem.
Once I bought my 8v GTI, after about a month the same thing started happening, not as bad, my mate (an ex VW technician) cleaned the inside of the throttle body - Never happened since!
Offline actionslax
Re: car stalling
« Reply #3 on: 08 September 2004, 13:33 »
i would do a search on this as it has definitely come up a few times before. i had/have this problem too.. the garage where i take it said it is quite common amongst other things. he cleaned out the butterfly thingamajiggy in the fuel line??? seem to sort it for 6 months or so.
slax
currently rattling:
1. To make or emit a quick succession of short percussive sounds.
2. Not anymore - Now rumbling
