Author Topic: battery problems  (Read 1973 times)
Offline daniel-1986
battery problems
« on: 07 August 2009, 21:53 »
is my battery coming to the end of its life, as it started first time this morning then was completley flat a couple of hours later, its done it a couple of times lately, i even took it for a motorway blast to put some charge in it last night but still went flat
gtigolfthree
Re: battery problems
« Reply #1 on: 07 August 2009, 22:10 »
You need to get the alternator checked out first to see if its charging the battery properky.
Offline daniel-1986
« Reply #2 on: 07 August 2009, 22:13 »
the alternator was new last year, well a recon anyway from gsf
gtigolfthree
« Reply #3 on: 08 August 2009, 09:22 »
Unusual for it to start in the morning and then go flat while driving if charging ok.
Offline Agreeable Slick
  • Unit
« Reply #4 on: 08 August 2009, 23:01 »
Do a search on here.
Check the regulator in the alternator.
Offline raferackstraw
« Reply #5 on: 09 August 2009, 00:25 »
with engine running put a multimeter across the battery terminals set to 20v dc you should see around 14v on meter with no ancillaries running
if your getting 14v battery is fooked  :wink:
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline daniel-1986
« Reply #6 on: 09 August 2009, 10:15 »
did that yesterday getting a reading of 14.1v with the engine running, i bought one of them portable jump starters the other day as i didnt want to spend the same money on a new battery only for it to go flat with in a couple of days of buying it
  • Unit
« Reply #7 on: 09 August 2009, 13:16 »
As I said check the regulator. It will still charge the battery when the engine is running, but it will not disconnect when the engine is stopped, and thus will keep pulling a charge from the battery until it is empty.
Offline daniel-1986
« Reply #8 on: 09 August 2009, 13:52 »
i'll check that next, i also put a multimeter across the the fuses and there was a 12v at the radiator fan, brake lights, radio/cigarette lighter etc and the emergency light (hazards) fuses, shud there be 12v at them plus how do i check if the regulator is at fault
« Last Edit: 09 August 2009, 13:55 by daniel-1986 »
Offline daniel-1986
« Reply #9 on: 13 August 2009, 11:06 »
i had a shop do a jump test on my battery and turns out it was knackered so bought another
