mk2 ecu wont work, and there is no maf sensor on a 16v.
There is only a map sensor in the ecu, and it wont work with this disconnected, or at least my mates 16v wouldnt when it had a gash in the map pipe. The vac line runs from the ecu to the inlet or chunky servo pipe non-return valve nipple, so check it hasnt fallen off or split.
if it was the imobilisor the car would run for a couple of seconds then cut out, so if it ran for longer than that but wouldnt rev then the issue is elsewhere. what year is it?
