VAG-com should confirm ecu fault.
Quote from: AudiA8Quattro on 11 August 2009, 11:53VAG-com should confirm ecu fault.in most cases it doesnt.Dont forget its the ECU thats giving out the fault codes, so if the ECU is shagged then its not necersarily going to give you the right data in the diagnostics
I would try the ecu and fuel injection relays first! They only cost about 12 quid each and dont show up on diagnostics!
