Author Topic: Mark V - Mark VI with ACC - Question  (Read 18506 times)
Offline et997
Re: Mark V - Mark VI with ACC - Question
« Reply #30 on: 16 August 2009, 16:24 »
Yes, mate, will report back.
Please check your PM. Thanks!
Offline howlingmoon
« Reply #31 on: 16 August 2009, 21:16 »
hmmmm either my arse is too fat or I cant tell the difference between sport, normal and comfort... I have driven the car more than an hour on the highway today and tried all 3 modes.... my passengers could not tell the difference either... ha ha ha maybe the 3 of us have fat arses...  :cool:
GTI Mk6 United Grey, 18" Monza Shadows, RNS310, Executive Package, ACC
Offline keelaw
  • It's here!
« Reply #32 on: 16 August 2009, 21:22 »
what are your roads like?  driving around london today, roads here in the city are pretty poor.  too many potholes, poorly repatched roads (after roadworks) and big speed bumps.  I think ACC in comfort mode will be ideal for the city.
Mk6 Golf GTI 5dr, DBP, Monza Shadow, Xenons, ACC, RCD510, Park Assist, Camera, Lux pack.... and now bluetooth.... and now DSG!
Offline howlingmoon
« Reply #33 on: 16 August 2009, 21:42 »
Dutch roads are in general quite good. Very smooth and no potholes. Of course there are tram lines and some uneven roads here and there but the highways are as good as the autobahns in Germany. Only problem is that there is a speed limit of 120km/h. Am going on a holiday in Germany next week and I will comment then... he he he hmmm need to run in the car still.... only 651km today...
Offline Carl Fredricksen
« Reply #34 on: 21 August 2009, 17:01 »
Anymore takers!?!?
Offline Spaced
« Reply #35 on: 21 August 2009, 18:05 »
Try my thread
http://www.golfgtiforum.co.uk/index.php?topic=123938.0
The upshot is that I thought the MK6 without the switchable dampers both handled and rode better than the MK5....just slightly.
Loyal owner since 2005, done with remapping, I drive a Golf not a Veyron. (hypocrite)
Offline Teutonic_Tamer
« Reply #36 on: 22 August 2009, 21:04 »
Try my thread
How old is your Mk5?  Maybe your suspension is nicely 'worn in', whereas the demo Mk6 will still have tight suspension.  A similar thing occured when some peeps swiched from the std Mk5 GTI to a newer Ed30 - they innocently thought it had different to the std GTI - when they are in fact identical.
I feel like a homo
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #37 on: 22 August 2009, 21:33 »
Try my thread
It maybe that i agree with you i have the same feeling going from our high milage company GTI mk5 to my own low miles one.
Are you saying the mk5 GTI and the mk6 GTI are identical? or simply tacking onto the end of that that the ed30 and GTI mk5s are identical? If so may i ask have you checked up that the mk5 and mk6 GTI suspension are identical with identical components and use exactly the same rates? I thought i read in a VW press release from germany they had changed something but cannot remember what for sure now it maybe was the rear antiroll bar? but i cannot remember for sure.
« Last Edit: 22 August 2009, 21:40 by Snoopy »
Current Garage:
35+ years of GTI ownership.
« Reply #38 on: 22 August 2009, 22:12 »
Try my thread
Yes, well within the usual weight-range differences.  The Mk5 and Mk6 have identical front and rear subframes, identical suspension arms and wishbones - which will all indicate identical geometery (again within the usual range of adjustments).  The actuall spring rates also appear to be identical, as do the dampers.  The only real difference is if you spec the ACC, or whatever its called - which substitutes the conventional 'analogue' dampers for the electronically controlled dampers.  These are exactly the same as the Audi TT.
An that too.
The 'hardware' (apart from the optional elec dampers) are identical.  The rates are more difficult - all I can say is that the full range of springs and dampers available for the Mk5 (variable due to the 'kerb weights') are the same offerings for the Mk6.  But weather say a Mk6 GTI with a kerb weight of say 1435 kgs has exactly the same rates as a Mk5 of 1435 - that I don't know.  :undecided:
Hmmmm . . . I don't always take 'press releases' as 'gospel'.  Even some of the official 'Technical Data Sheets' get things wrong - the gear ratios for the DSG gearbox are a classic example!  :rolleyes:  But maybe they have increased spring and damper rates, along with beefier ARBs - and the ARBs are something I haven't checked!  :embarassed:
I feel like a homo
« Reply #39 on: 23 August 2009, 08:05 »
ARB's? What's that in layman terms?
cf
