Author Topic: Mk3 Advice needed  (Read 2860 times)
Offline mjb
  • Mk3 Addiction
Mk3 Advice needed
« on: 05 August 2009, 10:06 »
Hi, just fitted a sony stereo in to my MK3 which I automatically thought eveything would be fine as the fittings apear to be exactly the same and i am getting no radio reception with sound and the cd player is playing with no sound?.....all the wires appear to be conected fine and I have even tried swaping the red and yellow ones around after reading a couple of threads to no avail!........anyone have any ideas?....or experienced anything similar?
Thanks
Instagram @mjbampt
Golf Mk7 Wagon (Work), Mk3 Gti 16v More Door, Mk3 Gti 8v (RIP)
Offline -o-l-l-i-e-
Re: Mk3 Advice needed
« Reply #1 on: 08 August 2009, 22:24 »
i had that problem with my my mk3 awhile ago, my problem was that i had the aerial removed so you if urs is damaged them maybe thats your problem? sorry if i'm teaching you to suck eggs, i was stumped for days when i had mine removed!
Offline troublestarter
« Reply #2 on: 08 August 2009, 23:33 »
a dodgy aerial wont stop a cd from giving any output
(sorry if its trying to teach you too suck eggs???)i think you might want to suck them yourself with excellent advice like that
check the light blue att/mute wire on the back of the sony stereo is not touching earth as that will cause the cd player and radio to not give an audio
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline mjb
  • Mk3 Addiction
« Reply #3 on: 09 August 2009, 17:45 »
Cheers for the advice guys!.....after all the racking of my brains and nearly pulling my hair out!, it turns out that it was the bloody stereo that was faulty!!!!...now the problem is it won't fit in properly....looks like i'm going to have to chop into the dash behind the stereo as all the wires wont fit back!!! it seems like the only way i'm going to get it to fit in flush. :evil:
Instagram @mjbampt
Offline MK3TDi1996
« Reply #4 on: 09 August 2009, 17:50 »
no no no no no!
no chopping! it will all fit, just take your time and guide the wires back as you EASE the stereo in...
« Reply #5 on: 11 August 2009, 23:39 »
take the glove box out that will give you loads of room to move the iso  loom to one side to allow the h/u to fit properly
Offline B-chi
« Reply #6 on: 14 August 2009, 18:02 »
Glovebox out, fit hu, pull wires to the left, refitglovebox, voila
Offline Shady Pioneer
  • graphic designer.
« Reply #7 on: 17 August 2009, 23:55 »
I managed to push all the cables at the back of my headunit down behind the heater controls. VERY fiddly but worth it in the end. But the above method works too. Just means it can be a pain at times if you need to remove the glovebox in the future having wires behind it.
Offline Jimp
« Reply #8 on: 18 August 2009, 19:21 »
I pushed the controlled behind the heater controls too with little hassle. Well worth it.
Not low enough mk5
Not on the road enough mk3
