Author Topic: Expected Idle Revs - 700 RPM????  (Read 3729 times)
Offline Kermit
« on: 04 August 2009, 13:38 »
Went to start my car today (never noticed this before) - struggled initially then fired up (only one key turn though), revs went to about 1100 and then the rev needle kind of "incrementally" dropped (maybe decrementally - hard to describe) to 700 - 100 a time.  I'm sure my idle has always been around 1000.  There are no warning lights on and took it out (hoping it woudn't break down!) and it felt a bit "flat" - revs seem to drop off too quickly (or differently to before)
I know not a very good description but any ideas appreciated (I know it could be a 1001 things)?  Sods law I need it tomorrow!  As no engine warning going to risk it but would like to get it into the stealers but with a bit if background info before they start replacing stereo and seats to fix it  :grin:
Car is standard
2007 GTI, Steel Grey, DSG with Paddle, Leather, 18" Monza, Xenons, Lux and Winter Pack, iPod, Tints
Offline ub7rm
Re: Expected Idle Revs - 700 RPM????
« Reply #1 on: 04 August 2009, 15:13 »
Starting off at high revs at roughly what you describe is normal when cold then drops down to 700/800 on mine too.  Perfectly normal.  If you have your a/c on though the normal idle will sit a bit higher.
2020 BMW 128ti
2017 Golf GTD Estate
Offline sambo
« Reply #2 on: 04 August 2009, 17:28 »
Sounds just like mine when I got it. Changed the PCV valve to no effect, then changed the DV and that fixed it. Would also explain loss of power :afro:
HTH Sam
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline Kermit
« Reply #3 on: 04 August 2009, 20:22 »
Thanks for the replies - sounds like the idle is ok then (maybe the only reason I noticed this was because of the stuttery start - normal just start and go  :cool:)
Any "idiots guide" to where the PCV and DV are and what to look for (maybe pics if anyone have them to hand) - don't spend any time under the bonnet  :embarassed:
Offline Teutonic_Tamer
« Reply #4 on: 15 August 2009, 14:02 »
If yours is the standard GTI (not Edition30 of Pirelli) then the DV is located on the turbo housing.  This is at the rear of the engine, near the bottom, so you need to jack up the car, or get it on a lift.
The PCV is much easier, though you need to remove the engine top cover.  It is a black plastic item, on the front edge of the cylinder head above the inlet manifold.
I feel like a homo
Offline GregR
« Reply #5 on: 17 August 2009, 22:54 »
Any Photos guys?
ta
Offline AlanD
  • MK5 2.0T 16v
« Reply #6 on: 18 August 2009, 09:45 »
lol Sambo posted some up the other day. Cant remember what thread now.
Offline Rhyso
« Reply #7 on: 19 August 2009, 09:42 »
useless Alan  :rolleyes:
Pics of DV in this thread here
 :tongue:
Offline synnea
« Reply #8 on: 20 August 2009, 08:02 »
Agreed, my R32 does it too, totally normal and nothing to be worried about.
R32 : DBP : Lux Pack : Winter Pack : Cruise : Leather : Parking Sensors : Rear Tints : Armrest : RNS 510 : Ipod MediaIn : FreeView Tuner : VagCom
« Reply #9 on: 20 August 2009, 12:02 »
 :tongue:
Found any links which have pics of the PCV?  :tongue:
I feel like a homo
