Author Topic: When should my fan be cutting in ?  (Read 2821 times)
Offline Grazy
« on: 03 August 2009, 09:57 »
Dont think i have heard fan running in the 3 months that the Golf  has been on the road , Temp gauge never goes above half way but in traffic or round town temp light comes on and flashes constantly . A bit of a hot rubbery smell come into car and to be honest worries me a bit , Any ideas people  :sad: Thanks
Re: When should my fan be cutting in ?
« Reply #1 on: 03 August 2009, 14:49 »
should come on at around 3/4 on gauge, see the coolant faq on tips on testing all the different parts of the cooling system
http://www.golfgtiforum.co.uk/index.php?topic=106380.0
Offline Jay
  • balding fat cvnt
« Reply #2 on: 03 August 2009, 20:06 »
Check your PAS and alt. belts. I had that smell and my alternator belt kept flipping out of the V and upside down  :angry:  I didn't bother fixing it because it failed the MOT not long after  :lipsrsealed:
Offline hughesy83
« Reply #3 on: 03 August 2009, 20:37 »
Sorry to jump in here btw, but my fan also comes on quite often, especially if i've been darting around town - although temp gauge never gets to half way... is my gauge bust or is that normal? I have a 16V and I understand they run hot.  :undecided:
Mk2 Golf GTI 16V
Mk4 Golf GTI 1.8T (AUM)
Offline Jay
  • balding fat cvnt
« Reply #4 on: 03 August 2009, 21:12 »
It can't do any harm can it?  :huh:
My 1.6's fan used to come on quiet a lot last year summer time, I knew this because the fan was buggered and made a racket and sounded like the engine was failing :grin:  :shocked:
Offline JC
  • Back in the North.
« Reply #5 on: 03 August 2009, 21:25 »
educated guess ?
Offline poncho
« Reply #6 on: 04 August 2009, 00:20 »
Hi,
My fan comes in at just before half way on a 1600 if thats any help
Andy
« Reply #7 on: 04 August 2009, 11:57 »
the gauge could be under-reading, what does the oil temp say? could be the fan switch is cutting in a bit early too. or you may have the after-run system fitted and the wire has fallen off and is earthing to the engine. its a single pin sensor with a black wire, on the inlet somewhere
Offline Grazy
« Reply #8 on: 04 August 2009, 22:16 »
 Ill check oil temp on next run rubjonny , Its a november 91 8v digi if that makes any difference , ,Sorry no good with motors so may struggle to find inlet mate  :rolleyes:
Offline Nate187
« Reply #9 on: 05 August 2009, 01:21 »
Mine comes in at 82 degrees on the oil temp, or is it 92  :undecided:
Its not a Gti without the stripe
