Author Topic: When should my fan be cutting in ?  (Read 2825 times)
Re: When should my fan be cutting in ?
« Reply #10 on: 05 August 2009, 08:51 »
82 oil temp is just warmed up, 92 would be more like it but still a bit cool
edit: though there can be a difference between oil & water temps, but 92 is still a fair bit cooler than i would expect for the fan to kick in
Offline Grazy
« Reply #11 on: 05 August 2009, 18:22 »
Ok , took it out today after about half hour of driving and with temp gauge on half way and the oil temp at 98 , still got hot smell coming in car Temp light flashing, stopped at petrol station filled up turned car on again no light flashing , then later it came on again ?? :undecided:
« Reply #12 on: 06 August 2009, 11:37 »
disconnect the plug from the header tank level sensor and bridge the pins, see if that stops it.  if so check the level, if its ok you probably need a new tank. if it doesnt then either the temp sensor is playing up or the dash clocks
Offline Grazy
« Reply #13 on: 06 August 2009, 15:28 »
OK , Thanks so header tank is where i put water in for cooling system yeah ?
How do i bridge pins - Excuse my ignorance  :embarassed: :embarassed:
If we are talkin same tank it looks pretty new  :rolleyes:
If i need new temp sensor where is that ??
if it was the clocks ( Have been replaced my low mileage ones by PO ) why would this make engine so hot and smell so hot ??  :huh:
Sorry for all questions Johnny but i know nothing about engines but feel this is a problem that needs addressing quickly , Thanks ALOT for your help  :wink:
« Reply #14 on: 07 August 2009, 08:35 »
yeah it is, to bridge the pins pop the plug off and put a bit of wire between the pins, on the plug obv not the header tank ;)
the temp sensor is the black 2 pin one in the flange on the front of the head, the clocks wouldnt make the engine run too hot, however engines do smell a bit when warm especially if say they are coated with oil due to leaky gaskets, or if oil is leaking onto the exhaust manifold :)
