Author Topic: Rough Idle  (Read 1107 times)
Offline Daston
Rough Idle
« on: 02 August 2009, 09:12 »
Hi guys,
Got my engine set at TDC, first attempt consisted of it running rather rich and then realised the dizzy had moved 2 teeth out. I have taken her for a quick spin round the block and once moving she is ok, however she will cut out when you come to a stop. The engine sometimes catches its self and stops if from stalling but not all the time, plus it sounds a bit like an air cooled dub at idle.
Having looked at the oil filler cap there is a bit of mayo in there, would a blocked crank breather cause it to idle so rough? I dont want to start ording parts left and right when theres no need to.
Dave
Offline Winner
Re: Rough Idle
« Reply #1 on: 02 August 2009, 11:31 »
that sounds to me like its not firing on all cylinders have u tryed pullin each plug cap off?
Offline Daston
Re: Rough Idle
« Reply #2 on: 02 August 2009, 17:32 »
cheers chap, turns out I didnt plug the plug in on injector 1 (doh). Runs a lot better now, however it seems to be smoking quite a bit on the over run. Plus there seems to be smoke coming from the manifold area.
Offline Steve_B
Re: Rough Idle
« Reply #3 on: 02 August 2009, 18:03 »
If you've just changed the head expect smoke from manifold area for about 10 -15 minutes. Quite normal apparently.
Offline Daston
Re: Rough Idle
« Reply #4 on: 02 August 2009, 18:52 »
Thats good I thought it was on fire the first time lol was about to push the car as far away from the TVR as possible
