Author Topic: mk3 tdi panic :( help needed :)  (Read 1717 times)
Offline vdubnut
« on: 01 August 2009, 21:27 »
...driving my mk3 today had a sudden loss of power steering and i think blurt of black cack out the back....seemed to happen with a squeely noise too...stopped car and it started again and drove fine. In Glasgow happened again with more squeely noices and a rubbery smell....sure there was smoke from bonnet too but couldnt find any evidence!
any ideas :( not that technically minded as you can tell!!  (oil and coolant levels fine, power steering level fine too)
gtigolfthree
Re: mk3 tdi panic :( help needed :)
« Reply #1 on: 01 August 2009, 22:03 »
Check your power steering pump belt something has happened to it. Its on the left hand side of the engine. (airbox side).
Offline richard157
« Reply #2 on: 02 August 2009, 09:11 »
if i was you id drop the belt off and make sure all the pulleys turn freely just to make sure notings jamming.also inspect the belt for any signs of slipping.you dont want to be losing your steering mid corner.
Offline vdubnut
« Reply #3 on: 02 August 2009, 09:30 »
is this easy to do? any good guides? haynes is not the best!
gtigolfthree
« Reply #4 on: 02 August 2009, 12:29 »
Visual inspection first if been smoking etc damage should be obvious. Let us know what you see, but I would get another belt anyway
Offline christomk3gti
« Reply #5 on: 02 August 2009, 12:32 »
I agree with these guys.
inspect it for any damage. replace belt. cheap and easy enough. like they say, dont want to loose steering in mid corner  :sad:
Black 8v GTI............. Whats a Waffle Valve?
Offline vdubnut
« Reply #6 on: 08 August 2009, 20:01 »
thanks guys :) inspected the belt and a few of the teath look fecked :( had new belt from halfords but way too long must be wrong one! VW on monday! for new one
gtigolfthree
« Reply #7 on: 08 August 2009, 20:19 »
Shouldnt be any teeth on power steering belt cambelt has teeth if its that dont start the engine. Pictures would help.
Offline vdubnut
« Reply #8 on: 08 August 2009, 21:12 »
http://www.golfgtiforum.co.uk/index.php?topic=72397.10 its the belt reffered to on this link ....lol splash guard on mk3 was fun...undertray time LOL!
Offline vdubnut
« Reply #9 on: 15 August 2009, 12:41 »
update : changed the belt for new one fitted new adjuster bolt too as this was knackered....still getting an odd noise though when turning right....fine left and straight on though.... any ideas.....sub 20 mph no noise and fine just seems noisier faster speed....
