Author Topic: mk3 tdi panic :( help needed :)  (Read 1719 times)
gtigolfthree
Re: mk3 tdi panic :( help needed :)
« Reply #10 on: 15 August 2009, 13:02 »
Yes thats the power steering belt, just make sure its at the correct tension.
Offline vdubnut
« Reply #11 on: 15 August 2009, 13:42 »
checked the haynes manual and its says deflection of about 5mm? wonder if its a bit tight.....
gtigolfthree
« Reply #12 on: 15 August 2009, 17:50 »
If its too tight it puts a strain on the pump bearing but its only if its too slack that it will squeal on full lock
Offline vdubnut
« Reply #13 on: 15 August 2009, 18:22 »
sounds like mine too tight then?   :undecided:darn! gonna have to dismantle and re assess?
Offline vdubnut
« Reply #14 on: 16 August 2009, 20:15 »
fingers crossed loosening the belt a little has fixed it :) cheers for all the help guys its much appriciated!
