Author Topic: Squeeky brakes  (Read 3023 times)
Offline matt_s
Squeeky brakes
« on: 31 July 2009, 12:46 »
I know squeeky brakes could be due to a few things. It could be dirt, pads need changing or something more sinister!
My brakes squeek during light breaking, if I break hard there is no squeek at all. The squeeking is also at its worst when the brakes have warmed up a bit.
Does this give anyone any clues as to what it could be?
Cheers in advance
Offline Mr_Orange
Re: Squeeky brakes
« Reply #1 on: 31 July 2009, 12:56 »
Cheers in advance
I'd be looking at new pads, they perhaps glazed up...  Does it squeak noticeably when just running normally, ie without applying the brakes?  Squeak change when turning at all or any steering feedback under braking?
My car is being looked at today for similar problems.  I know the disc has warped again (brakes juddering), so I'm waiting for news of a possible sticky caliper and maybe problems with the hub / bearing   :sick:
Build thread clicky
Offline matt_s
Re: Squeeky brakes
« Reply #2 on: 31 July 2009, 13:40 »
Hi, thanks for replying.
No, there is no squeeking when running normally...only when braking. The squeek does change when i turn in both directions. What does this mean? No judder problems whatsoever.
« Last Edit: 31 July 2009, 13:49 by matt_s »
Offline rheady
Re: Squeeky brakes
« Reply #3 on: 31 July 2009, 13:57 »
Take your front wheel off and check the condition of the pads. The outer one might look ok but the inner one will run down more.
Offline Wurzel
Re: Squeeky brakes
« Reply #4 on: 31 July 2009, 19:20 »
Check the pads and discs. And you can replace them fairly easily yourself, no need to bleed the brakes for this. Save yourself a fortune. Buy Mintex pads on ebay.
1999 mk4 1.8 n/a AGN Silver Grey
***Looking for one 16 inch wheel, Montreal 2*** and a rear parcel shelf (without speaker holes!)
Offline johnson6672
Re: Squeeky brakes
« Reply #5 on: 31 July 2009, 22:19 »
Anti rattle shim/plate behind the pads either missing or not working properly, some people don't change them with new pads as they don't always come with new ones.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline johnaldinho89
Re: Squeeky brakes
« Reply #6 on: 31 July 2009, 22:45 »
woudlnt want any of use working on my car then lol squeeky brakes is usually corrosion and dirt stuck onto the pad carrier and when applying the brake the squeek is the dirt on the pad onto the disc causing this annoying noise, strip down ur front brakes clean the pad carriers+pads up regrease them and you should be sorted mate , bearing in mind the pad has life left in it obviously
Offline Matty-MK3
  • Automatic boats FTW.
Re: Squeeky brakes
« Reply #7 on: 31 July 2009, 23:28 »
Check the pads.
Someone on Edition38 wrote a guide for the MK3 pad change, pretty much the same as the MK4. I'll link it to you when it's back.
Could be many things though.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline northeast_gti-t
  • "1.8T AGU"
Re: Squeeky brakes
« Reply #8 on: 01 August 2009, 01:24 »
i have the same noise from my front pads when i paint my calipers im removing the pads and putting some anti seize compound on the backs of the pads as in my experience this will be causing the noise
2000 Mkiv GTi 1.8T AGU
Offline matt_s
Re: Squeeky brakes
« Reply #9 on: 02 August 2009, 11:46 »
Also forgot to add that the squeeking dissappears when its wet.
Does that help anymore?
