Author Topic: 8v Digi Rear Engine Mounting Replacement  (Read 1257 times)
Offline jezza16v
« on: 30 July 2009, 19:43 »
Hi, replaced the front engine mount last week, much better now but there's still quite a bit of movement in the engine when pulling away, it seems like the rear mount (not gearbox) is shot as well. I've had a good search but can't find a guide for changing it. Can it be done with the engine in place? I did the rear mount on a late 16v a few years back (it was a pig) but it seems the mount on the late 8v are different to 16v? Thanks.
Re: 8v Digi Rear Engine Mounting Replacement
« Reply #1 on: 30 July 2009, 20:34 »
It is a bit tight but not too hard to do.
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 31 July 2009, 09:37 »
Get the car on ramps, if you can - will make life a lot easier.
Release the top of both rear mounts and jack up the drivetrain a bit - it'll probably trap on the exhaust or driveshafts first.
Undo the bolt that goes through the mount you're replacing and slide it out.  Slide in a new one, bolt it up, lower the engine back onto the mounts and replace the bolts/nuts on the top of the engine mounts.
Offline jezza16v
« Reply #3 on: 31 July 2009, 10:27 »
Thanks, awkward, but straight-forward it seems then.....
