Author Topic: Torque Gain  (Read 3197 times)
VW BUSH
Re: Torque Gain
« Reply #10 on: 30 July 2009, 17:45 »
Leave well alone for a few more years, as the Mk3 rusts it's power to weight ratio increase in your favour :wink:
gtigolfthree
Re: Torque Gain
« Reply #11 on: 30 July 2009, 17:47 »
Interesting article on camshafts, torque and power if anyone can be bothered reading it. Goes on a bit.      http://www.cannell.co.uk/Technical%20Articles/pwr_tq_explain.htm
« Last Edit: 30 July 2009, 17:55 by gtigolfthree »
Offline earlbob
Re: Torque Gain
« Reply #12 on: 30 July 2009, 19:53 »
Expensive but im pretty sure if you increase the compression or decide on a bigger stroke then you will have some torque gains, and the turning power will beef up but after all that... just buy yourself a vr6 lump and fit it or have it fitted???
Just what I know... and would suggest... :D
gtigolfthree
Re: Torque Gain
« Reply #13 on: 30 July 2009, 20:01 »
You cant increase the stroke, only the bore by means of a rebore and new pistons.
gtigolfthree
Re: Torque Gain
« Reply #14 on: 30 July 2009, 20:26 »
Thats amazin, so what can you go to by diong that and the max safe rebore?
gtigolfthree
Re: Torque Gain
« Reply #15 on: 30 July 2009, 20:30 »
Would the pistons not hit the valves though if you increased the stroke?
Re: Torque Gain
« Reply #16 on: 30 July 2009, 20:32 »
No because the pistons we used were shorter to allow the longer stoke, the block had to modified as well for clearance, was a awesome engine however so much torque.
Offline Reasty
  • Alpine white valver.
Re: Torque Gain
« Reply #17 on: 30 July 2009, 20:35 »
Fit a good four branch manifold(no not one off ebay)and you will gain torque,bhp drivability, and it will pretty much erradicate the flat spots.
gtigolfthree
Re: Torque Gain
« Reply #18 on: 30 July 2009, 20:44 »
Yes its all about gas flow, more gas in and more gas out.
Offline Ess_Three
Re: Torque Gain
« Reply #19 on: 31 July 2009, 11:22 »
that looses torque at the bottom end!
That depends on the cam choice, and headwork done.
I got a 25 BHP gain out of my head and cam set-up...with a gain it torque everywhere.
If you are careful about selecting cams and setting them up, you'll not always loose torque.
..but gaining motorcycles.
