Author Topic: does this look right?  (Read 3916 times)
Re: does this look right?
« Reply #10 on: 29 July 2009, 20:59 »
what is worn? cause at the mot they only replaced the top mounts.
scott
It is the top mounts that have failed again or have not been put together correctly.
Offline AudiA8Quattro
« Reply #11 on: 29 July 2009, 21:13 »
They are not normal, whether lowered or not.
They are worn out, and need to be replaced.
Mine and alot of other people here have that happening with lowering.
Does it creak and knock when turning?
This tends to happen when poor quality mounts are used.
The rubber goes out of shape.
They should be replaced when they look like that.
Here is what they should look like:-
http://vwpolo2000.proboards.com/index.cgi?board=suspension&action=display&thread=236&page=1
« Reply #12 on: 29 July 2009, 21:14 »
scott
If new mounts have been recently fitted then they are poor quality items.
Offline gtiscott
« Reply #13 on: 29 July 2009, 21:17 »
its going in on friday to get new front brakes so i will tell them to redo the mounts, thanks for the replies guys
scott
Offline gtiscott
« Reply #14 on: 29 July 2009, 22:06 »
could this cause a kind of banging noise when breaking? , i put it down to my brakes but.....
« Reply #15 on: 29 July 2009, 22:09 »
Hard to say, but it is possible.
The only way to tell is to jack the car up, grap the spring and see if there is any 'give'
Offline gtiscott
« Reply #16 on: 29 July 2009, 22:26 »
will try that tommorrow and see what happens, thanks for the help :smiley:
Offline gtiscott
« Reply #17 on: 31 July 2009, 12:19 »
just go it back, guy said top mounts are fine, although he took them off and replaced them anyway, needed new brake pads as one had split and was stuck to disc
scott
« Reply #18 on: 31 July 2009, 12:46 »
scott
Has the gap now gone?
Offline gtiscott
« Reply #19 on: 31 July 2009, 16:50 »
yes it has
