Author Topic: does this look right?  (Read 3906 times)
Offline gtiscott
« on: 29 July 2009, 17:55 »
just noticed today that both sides sit like this and move about when steering wheel is moved is this normal?  I had new top mounts done for mot and hadn't noticed this before
http://i194.photobucket.com/albums/z280/gtiiiiiii/100_0732.jpg"
cheers
Scott
Offline VW Mel
Re: does this look right?
« Reply #1 on: 29 July 2009, 18:01 »
What level of ground was this pic taken on? Was it on a slope or anything?
Offline gtiscott
« Reply #2 on: 29 July 2009, 18:11 »
slight incline of my driveway and wheels turned slightly, so is this normal
Offline Adam
« Reply #3 on: 29 July 2009, 18:14 »
normal if you have lowered it.
Down Hill From Here.
Offline gtiscott
« Reply #4 on: 29 July 2009, 18:26 »
not lowered, totally standard set up
Offline VW Mel
« Reply #5 on: 29 July 2009, 18:36 »
I would see what it looks like on flat ground with the wheels straight as Mikesters looked a bit funny but was fine after we looked at it on flat ground with the wheel straight :smiley:
Offline AudiA8Quattro
« Reply #6 on: 29 July 2009, 18:40 »
They are not normal, whether lowered or not.
They are worn out, and need to be replaced.
Offline Adam
« Reply #7 on: 29 July 2009, 18:45 »
Mine and alot of other people here have that happening with lowering.
Does it creak and knock when turning?
« Reply #8 on: 29 July 2009, 19:28 »
Mine had a gap when I lowered it but those are shot and need replacing asap.
Offline gtiscott
« Reply #9 on: 29 July 2009, 20:57 »
what is worn? cause at the mot they only replaced the top mounts.
scott
