Author Topic: Too tall for the seats...  (Read 6058 times)
Offline Gloves88
« on: 29 July 2009, 10:01 »
I have a little issue that I think I can solve but need to ask if it'll work.
Basically I only just fit into the car lol...got the seat in the lowest position and my head still touches the roof. Being a German car you'd have thought it would cater well for tall people lol  :grin:
I'm pretty sure I read that I can fit corrado seats as the sub frame fits. Also heard that the corrado seats are a little lower? Is this correct? This would hopefully give me a little more head room lol
Only thing is that I like the material that I currently have on the seats so....would it be possible to transfer the foam and covering from my GTi seats onto the lower corrado sub frames?
If i cant do this i'd like to fit the rear corrado bench as well to get everything matching, does it fit no probs?
Basically:
1. Do corrado front seats fit?
2. Are the corrado seats lower than mk2 ones?
3. Can the mk2 gti trim be transferred to the corrado sub frames and still sit lower?
4. Does the corrado rear bench fit?
If anyone here could advise it'd be much appreciated  :smiley:
Re: Too tall for the seats...
« Reply #1 on: 29 July 2009, 10:27 »
1 yes
2 yes
3 no
4 yes if you weld in the corrado bench brackets or make a frame to attach rado bench to mk2 hard points
Offline Gloves88
« Reply #2 on: 29 July 2009, 10:53 »
Can I get scirocco or corrado seats in the grey white red black seat pattern?
Offline danny_p
« Reply #3 on: 29 July 2009, 10:54 »
i have sirrocco seats in mine for the very same reason,   so dose diamondhell
all the VW's have gone bar 1.
Offline Horney
« Reply #4 on: 29 July 2009, 10:55 »
And I run Rado seats in my trackcar as they're much lower. Proabably the best 80's seat VW produced. Much more supportive and comforatble than the golf ones.
nick
VeeDubGTI16v
« Reply #5 on: 29 July 2009, 10:59 »
you can move the seat back another 'click' if you drill out the last hole on the rail that usually holds the sprung adjusting pin and bolt it through the mount. only drawback is its not quickly adjustable. im guessing if your heads hitting the ceiling your legs are a bit cramped as well  :laugh:
Offline Reasty
  • Alpine white valver.
« Reply #6 on: 29 July 2009, 11:34 »
I had corrado seats in my mk2 before I got my leathers and bassically u sit on the floor pan when in the lowest position.
Offline bomp
« Reply #7 on: 29 July 2009, 11:41 »
Just retrim them yourself, it's time consuming but not too hard.  A pair of front scirocco seats I did a while ago, just need to make a rearbench I like the look of now.
Going to make a Recaro headrest for them as I like the shape of them rather than the thin standard type. Just need to take a mould of the Recaro headrest first.
Also, I think that the Toledo reabench fits straight in (1991 - 1999) as the Toledo was built around the MK2 Chassis.  Two types:
« Last Edit: 29 July 2009, 12:34 by bomp »
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
« Reply #8 on: 29 July 2009, 12:17 »
some scirocco seats can be had in MK2 patterns, I've seen them in the red/black stripe pattern, look nicer then the MK2 seats as well :)
Offline maxp
  • J reg 8v digi gti
« Reply #9 on: 29 July 2009, 13:55 »
Mate that looks bloomin awesome. Did you do that all yourself? Any idea how long it took? Does the black show dirt quite easily?
