Author Topic: Losing power over bumps  (Read 1316 times)
Offline mk2mark
« on: 29 July 2009, 08:43 »
I have this very strange problem with the golf, it periodically loses power in varying degrees. This could happen at 80mph on a flat motorway, or the minute I pull out of the driveway in the morning. The only thing I have noticed is that going over a bump sometimes triggers it, which says to me something may be loose - but what?
When it loses power, it could be to any degree - it could lose a little power or pretty much all of it. When it does the car feels asthmatic, and when it's bad the exhaust sounds like it's sputtering. I don't think it's the dizzy cap/rotor or leads as I've recently replaced these. Any ideas?
Offline Ben Lessani
Re: Losing power over bumps
« Reply #1 on: 29 July 2009, 09:02 »
Dodgy earth
Offline mk2mark
« Reply #2 on: 29 July 2009, 14:31 »
Could well be, which ones do I check, and is a multimeter any use?
Offline fishnchipsx2
« Reply #3 on: 29 July 2009, 19:08 »
If it's a PB, could be the plug on the MAF sensor?  Worth checking it's not corroded at all...
Offline l333
  • mk2 8v....mk3 8v....mk3 16v.... who says im greedy
« Reply #4 on: 29 July 2009, 23:24 »
hi could be a number of things have had problems with the ecu wiring plug corroding up, blocked exhausts, loose earth to gear box ect ect  best bet is start with simple stuff make sure all plugs are in properly all earths r good an tight and go from there
Offline mk2mark
« Reply #5 on: 30 July 2009, 08:39 »
Blocked exhausts?
