Author Topic: Cost of welding..  (Read 1922 times)
Offline Llewellyn
Cost of welding..
« on: 27 July 2009, 00:33 »
As i mentioned a while back the Monza has a big hole on the inner skin around the filler neck.  I mean big.
Anyway, i was just wondering on a rough guide to having it welded and the difficulty level.  Ive got too much stuff on at the moment and a welder that needs sorting to do it myself.  It doesnt need to be pretty, just MOTable.
thoughts would be appreciated
J
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline Diamond Hell
  • Opinions я Us
Re: Cost of welding..
« Reply #1 on: 27 July 2009, 13:14 »
I'd imagine the position of that's going to make it almost exquisitely car-breakingly expensive to get sorted, unless you're going it yourself.
The hole is by the filler neck, which means the tank will need dropping to facilitate access and remove the risk of blowing it all up.
If I was pricing it I'go in close to a grand by the time it's painted in and re-assembled etc.  AND that would depend on the tank dropping and going back OK - there's a huge opportunity for things to get worse before you can even do the welding.
Offline Ben Lessani
« Reply #2 on: 27 July 2009, 13:45 »
How do you actually go about fixing the above - can you just chop the filler neck out of a good car and weld it in place? Or is it all double skinned?
Offline Llewellyn
« Reply #3 on: 27 July 2009, 14:03 »
^^^ that was my thought, its not paint work, so that saves a fair bit of hassle.  Just really dont want to break it, cos i love small bumper Monzas and its a early car.  but i think i might have too
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline Horney
« Reply #4 on: 27 July 2009, 14:28 »
Mark just had to have a bit done on his. If you can find someone who's willing to weld and do it at yours it'll be cheaper. Strip the car down and prep it, get them to weld and then you can re-assmeble.
nick
« Reply #5 on: 27 July 2009, 15:00 »
heres a post about the job, some pics of whats going on behind the outer skin:
http://clubgti.co.uk/forum/showthread.php?t=31001
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #6 on: 27 July 2009, 19:27 »
This is a problem on the older Golfs. A chap at work has the same problem and he has bought a new panel complete with the petrol filler hole. He has to chop out the old rusty panel then graft the new one in place. probably alot of work, but do-able. look at the rest of the car first though. If that is the only rust then the car may be worth doing. if the sills are gone then think about alternatives. :lipsrsealed:
Offline Mac76
« Reply #7 on: 27 July 2009, 19:51 »
If i was going to do it as a job i would charge around £450 painted depending on how bad the rust is behind the filler as that may need repairing as well.
If you wanted just the panel welded and filled then probably £200 but your best off getting it done all at once
Cheers Marc
Offline aaron1980
« Reply #8 on: 27 July 2009, 20:58 »
Are you sure it will fail the mot?
Offline Llewellyn
« Reply #9 on: 27 July 2009, 21:14 »
The car needs no paint at all,  its only the inner skin that is rotten.
Mk2 GTI 16v
Mk2 Scirocco 8v
