Author Topic: Dual Door Wheel Arch Builds..  (Read 2379 times)
Offline Red_Tekk
« on: 23 July 2009, 08:58 »
What would happen if you built a sub into both wheel arch spaces as in the two stickies above...
Would you notice any cross phasing as the subs would be facing each other?
Would this be comparible to a double bass box? Better or Worse?
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: Dual Door Wheel Arch Builds..
« Reply #1 on: 23 July 2009, 16:56 »
They are too far apart to create any problems imo. DO IT!
Offline Red_Tekk
« Reply #2 on: 23 July 2009, 19:29 »
Any other opinions?!?
I think I might just try it, whats the worst that can happen ey?!
Will post up a how-to/progress guide on the way
Offline Len
« Reply #3 on: 23 July 2009, 20:58 »
Not really possible unless you build out the offside a long way as the petrol filler neck plus the petrol flap locking and the air pump for central locking is all in that side and dont leave a lot of room!
« Last Edit: 24 July 2009, 20:51 by Len »
www.sas.org.uk
www.the-ace.org.uk
Offline russ-vdub
« Reply #4 on: 24 July 2009, 11:06 »
Not really possible unless you build out the offside a long way as the petrol filler neck plus the petrol flat locking and the air pump for central locking is all in that side and dont leave a lot of room!
Surely if you were serious some of that stuff could be relocated? Correct me if i'm wrong of course, don't own a boat you see :P
Offline Len
« Reply #5 on: 24 July 2009, 20:53 »
Well believe me I thought about it!
I also had a huge problem locating my amp over that arch due to the amount of stuff located there!
The problem is depth, not area.
www.sas.org.uk
www.the-ace.org.uk
