Author Topic: help:) fitting hottuing coilovers  (Read 3337 times)
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
« on: 20 July 2009, 14:46 »
do you need spring clamps on the standard suspension when changing to coilovers?
Offline LazyLunatic
  • MK3 20VT Project
Re: help:) fitting hottuing coilovers
« Reply #1 on: 20 July 2009, 14:51 »
if you dont have new bearings or you need any bolts off the old ones, then you will need to compress the springs to get ahold of these bits. a few g clamps should do the trick. worked for me :afro: not the safest/best idea but most people have them and easier to get ahold of than a spring compressor.
« Reply #2 on: 20 July 2009, 15:09 »
You should not need them to be honest unless your reusing the old top mounts which is false economy, nothing else is needed from the old susp.
Offline shepgti
« Reply #3 on: 21 July 2009, 09:48 »
other than the little bit of metal that holds the brake line :wink:
« Reply #4 on: 21 July 2009, 10:01 »
On mine that would not work, I had to cable tie them to the legs.
Offline shepgti
« Reply #5 on: 21 July 2009, 17:27 »
you mean you couldnt make it work  :wink:
Offline johnson6672
« Reply #6 on: 21 July 2009, 19:14 »
Spring compressors are between £10 and £20 from  an auto factors, better than a coil spring in the face.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline christomk3gti
« Reply #7 on: 21 July 2009, 19:19 »
I made my own, 2 pieces of threaded bar (from work) and 4 aluminium blocks, shaped into clamps for the springs to slot in and 4 nuts. saved me some coin, and works great, loadsa ppl borrow them to change there shocks....
but if your not that good at making things, then spend your coin and buy some  :wink:
Black 8v GTI............. Whats a Waffle Valve?
Offline Grim_Reaper
  • warningz...i haz powaz
« Reply #8 on: 21 July 2009, 20:05 »
i use a thick ratchet strap to hold the spring in place  :tongue: :embarassed: hasnt failed me so far  :embarassed: :laugh:
« Reply #9 on: 21 July 2009, 20:54 »
No my hottuning coilovers had 2 small rings welded to the legs and was different to standard so I cable tied the brake hoses to those, was fine and still is.
