Author Topic: Mk3 Rear speaker wiring problem  (Read 4234 times)
Offline stu 88
  • Looking for a cheap set of 17's
« on: 18 July 2009, 20:10 »
Im half way through changing the rear speakers in my 5 door Mk3 gti - The old speakers have 2 plugs on it both with 2 wires coming out of each, 1 plug has 1 Brown/Red wire and 1 Blue/Green wire  - The other plug has 1 Blue wire and 1 Brown/Yellow wire,
So I have 4 wires but only need 2  - What ones do I use????
Plese help
Thanks
jedimasterlewis666
Re: Mk3 Rear speaker wiring problem
« Reply #1 on: 16 September 2009, 11:37 »
i am having this problem as well, any help would be very handy!
Offline Deano2711
  • 1992 VR6
« Reply #2 on: 16 September 2009, 12:16 »
Hi     Never messed with these so just guessing really but the reason for the four wires instead of two is more than likely due to the tweeters built into the rear door. If you want to disconnect the tweeters in the door then connect the stereo and turn it on. Use the one wire from one side to determine which one powers the speaker and which one powers the tweeter. Then repeat the procedure for the other two wires. Then you will have the two wires you need for your new speakers.
Hope this helps
Cheers     Dean
Offline Len
« Reply #3 on: 16 September 2009, 12:25 »
Think you need the wires with brown stripe on!
There is a thread about this on here so do a SEARCH!
www.sas.org.uk
www.the-ace.org.uk
jedimasterlewis666
« Reply #4 on: 16 September 2009, 12:59 »
did a SEARCH! but could find the answer so i replied to an old thread
Offline Len
« Reply #5 on: 16 September 2009, 13:04 »
I assume you mean you Could Not find an answer!  :rolleyes:
It may well have been in the Mk 3 Section.
But anyways its easy enough to establish which are the tweeter wires by just looking!
Then do as described above!
www.sas.org.uk
www.the-ace.org.uk
jedimasterlewis666
« Reply #6 on: 16 September 2009, 14:57 »
regarding the front speakers i have just bought new front componants but would i be able to leave the standard front tweeters in and just wire up the 6.5" ones? cant be arsed to fiddle about with the old tweeters while they still work.
Offline Len
« Reply #7 on: 16 September 2009, 15:36 »
You can as I did that coz I put 3 ways in the doors originally.
But you will get a better performance with the new tweeters.
www.sas.org.uk
www.the-ace.org.uk
