Author Topic: Fog light wiring to non GTI...  (Read 6178 times)
Offline MK3TDi1996
« on: 15 July 2009, 15:09 »
A how to do this would be appreciated - i've got the 2-stage headlamp switch and the fogs, just not the wiring know how!
ianw3321
Re: Fog light wiring to non GTI...
« Reply #1 on: 15 July 2009, 16:26 »
As an auto electrician I woulnt reccomend a complete novice to do this but anyway take a live feed from the dip beam either at the headlight or under the dash (reccomended) to the fog light switch then to relay, other side of relay to earth (look at relay wiring diagram). Ignition feed to relay preferably from a spare fuse in the fusebox and other side to fog lamps, other side of fog light bulb to earth. Repeat if you are not confident leave it to the profesionals as you could cause a fire plus we need to earn a crust too.
Offline christomk3gti
« Reply #2 on: 15 July 2009, 17:41 »
we need to earn a crust :grin:
lol
Black 8v GTI............. Whats a Waffle Valve?
ianw3321
« Reply #3 on: 15 July 2009, 18:32 »
As in bread.  :laugh:
Offline MK3TDi1996
« Reply #4 on: 15 July 2009, 18:45 »
lol cool man, i'm okay with electrics, just need to know where to etc...
you mentioning the relay wiring digram, where might I find this?
Thanks!
ianw3321
« Reply #5 on: 15 July 2009, 19:32 »
Should be actually on the relay a little coil of wire is the activator the fog switch one side the other to earth. and a pair of contacts one to live feed at fuse box other to fog lamps. Hope that helps.
Offline VR6-Joe
« Reply #6 on: 15 July 2009, 22:50 »
Could just go to a scrapyard, find a headlight loom for a Mk3 with fogs, and swap it with yours.
It will be the whole loom that connects into the round connector block attatched to the slam panel.
There will be 2x plugs for the headlights, 2x plugs for the indicators, 2x plugs for the fog lights, and also plugs for the horn
Or is that too easy :rolleyes:
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Mikester
  • Civic Type R
« Reply #7 on: 15 July 2009, 22:55 »
Was going to say this, and agree. And wont cost you sod all. And be plug and play.
Offline MK3TDi1996
« Reply #8 on: 16 July 2009, 08:18 »
cheers gguys, i'm liking the plug and play option - hadn't realised it was a seperate loom!
Offline vdubnut
« Reply #9 on: 19 July 2009, 23:07 »
did this on my tdi :) got the loom and fitted that ! sorted :)! big improvement. routing the wires was a sod in places tho!
