Author Topic: Water inside of boot (Where spare tyre is kept)  (Read 3081 times)
Offline luke0380
« on: 14 July 2009, 23:45 »
has anyone had this problem before ?
I opened the boot today and noticed in the corner on the carpet that covers the spare wheel it was wet .....  now i have noticed this before but put it down to a bottle of water i had in the boot which could of leaked.
Anyway i lifted the carpet up and there quite a substantial amount of water in the well where the tyre was and underneath the carpet.
Not sure how it would of got it , and it has been raining on and off the last few days.
Car is still under warranty so i will have to speak to them about it i guess, but just wondered if anyone has experienced anything similar.
Re: Water inside of boot (Where spare tyre is kept)
« Reply #1 on: 14 July 2009, 23:49 »
Tail light seals maybe.
Offline ub7rm
« Reply #2 on: 15 July 2009, 07:12 »
Does your rear window scoosher work properly?  VW's are famous for the pipes popping off in the rear tailgate...
2020 BMW 128ti
2017 Golf GTD Estate
Offline luke0380
« Reply #3 on: 15 July 2009, 07:33 »
sc00sher ??
Offline Spaced
« Reply #4 on: 15 July 2009, 08:22 »
I had this happen once and I am convinced it was that the tailgate wasn't shut properly as it has never happened again.
Loyal owner since 2005, done with remapping, I drive a Golf not a Veyron. (hypocrite)
Offline bobotheclown
« Reply #5 on: 15 July 2009, 10:00 »
sc00sher ??
rear washer jet? possibly. If that doesn't work then the pipe might have disconnected therefore washer fluid is being pumped into the spare wheel well instead of the nozzle on the tailgate.
Offline ub7rm
« Reply #6 on: 15 July 2009, 12:10 »
sc00sher ??
Rear window squirter... obviously just a scottish phrase then.. :grin:
2020 BMW 128ti
Offline ifti
« Reply #7 on: 15 July 2009, 13:34 »
I'll go check mine later!
Offline FamilyDub
« Reply #8 on: 15 July 2009, 14:22 »
sc00sher ??
Knew exactly what you meant!  :laugh:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline chrissyr32
« Reply #9 on: 15 July 2009, 19:46 »
It will defo be the tail light seals, got mine done on my R32 under warranty.   :wink:
