Author Topic: cost of a gearbox change...  (Read 7037 times)
Offline AudiA8Quattro
Re: cost of a gearbox change...
« Reply #20 on: 19 July 2009, 19:06 »
mine is a 02a gearbox..
ive got 2 litre of castrol driveline syntrax which i was gonna try first....
is that ok?
Yes, thats good stuff.
Offline yorkshire_gti
« Reply #21 on: 19 July 2009, 19:12 »
thanks....
Just need to try and get the topup nut off...it aint shifting at all   :angry:
maybe i need a better hex socket as the one from halfords is a crap fit...
Offline Grim_Reaper
  • warningz...i haz powaz
« Reply #22 on: 19 July 2009, 23:16 »
topnut, you mean on the shock??? you dont have to do anything with suspension man :/
and the gearbox bolts are not hex, they are torx ones so be careful with what you do man
« Reply #23 on: 19 July 2009, 23:40 »
I meant the 17mm  on the front of the gearbox for putting the oil back in...
I said the top one as its a lot higher than the drain plug  :)
Offline Grim_Reaper
« Reply #24 on: 20 July 2009, 13:08 »
oh right :o lol
as for halfrauds toolkits, if your using the multifit ones then they are crap and yes, they are a crap fit, if you use the deep sockets they are proper hex shaped, and wont round the bolt off like the other ones :doh:
