Author Topic: cost of a gearbox change...  (Read 7037 times)
Offline perd999
Re: cost of a gearbox change...
« Reply #10 on: 15 July 2009, 16:14 »
I remember getting mine done a few years ago for around £200 mark (including gearbox but they kept the old one)
Offline omex_uk
« Reply #11 on: 16 July 2009, 10:22 »
Quote
have you got the box? if so il chat to my mate whos a mechanic and changed my box for me
Yes,Ive got a box ready to go in...
would i need to remove the driveshafts on the car to stick the new box in or
can i just unbolt them at the gearbox end?
haha i just had a look and your like 4 hours from us. never mind :P
Offline Grim_Reaper
  • warningz...i haz powaz
« Reply #12 on: 17 July 2009, 19:14 »
you can remove the shafts from the gearbox, which is what i just said to you to do!!! iirc, there are 8 torx bolts that you will most likely round off if you dont use the correct size lol, but you can always bash a bigger size into it (ive done this 3 times now due to correded ones)...shafts will then pull off, then there are a few bolts that you need to remove to get the box off (iirc there are 4 19mm's and 1 10m but i cant remember off hand!)..before you remove the gearbox or the shafts remove the starter motor which is 3 bolts and keep it to a side...and also remove the clutch cable, its got that plastic hook thing on the end which keeps the cable from going through its protective sheeth thingy...its an easy peasy job, 3 hours max really
Offline Manxmann
« Reply #13 on: 17 July 2009, 19:46 »
The 02a in the 16v has a hydraulic clutch  :wink:
Offline Grim_Reaper
« Reply #14 on: 17 July 2009, 19:49 »
oh i wasnt anticipating that.....cable clutches FTMFW!!!!!
Offline yorkshire_gti
« Reply #15 on: 17 July 2009, 21:04 »
Thanks for that.....
will probably have a go when the rain finally stops
mine grinds in 2nd and 3rd which is very annoying.   :rolleyes:
If i sit on the drive with the engine running it goes into 1st fine but grinds into 2nd(does that sound like the gearbox?)..the clutch is quite new
« Last Edit: 17 July 2009, 21:14 by yorkshire_gti »
Offline boneybradley
  • Back in a Mk3...
« Reply #16 on: 17 July 2009, 21:37 »
before fitting a new box change the oil to some good synthetic stuff (you might need a motorsport supplier?) as these can sort lots of issues with the 020 boxes
« Reply #17 on: 17 July 2009, 22:11 »
mine is a 02a gearbox..
ive got 2 litre of castrol driveline syntrax which i was gonna try first....
is that ok?
« Last Edit: 17 July 2009, 23:08 by yorkshire_gti »
Offline P6UL K
  • VW Golf Mk3 GTi 8v 1997 FTW.
« Reply #18 on: 19 July 2009, 17:33 »
I'm thinking of changing my box, not to hard.... Just fiddly.
Cheers,
Paul.
« Reply #19 on: 19 July 2009, 18:57 »
Anybody know what size the hex bolts are on the driveshafts?
« Last Edit: 20 July 2009, 14:18 by yorkshire_gti »
