Golf mk3
hardmonkeys
Windscreen scuttle panel seal
Topic: Windscreen scuttle panel seal (Read 6626 times)
Mikester
Forum addict
Civic Type R
10 July 2009, 21:14 »
Mine is starting to lift up, and look mega worn?
Are these replaced with the windscreen? Or can it be done seperatly?
Worried its getting water down there, which isnt going to be good im sure.
What can i do?
Mike
Wayne
Sir Postalot
Re: Windscreen scuttle panel seal
10 July 2009, 23:40 »
Part of the windscreen seal from memory, your best bet is to try a local glass company and see if they can replace it.
Guy
Forum addict
12 July 2009, 09:22 »
its part of the scuttle panel mike and not part of the windscreen
about 70 notes from a main dealer but well worth it as it does smarten up the front of the car
** need web hosting? contact me **
ace
12 July 2009, 10:06 »
yeah it is part of the scuttle, as i found out!!!!!
think was about 70ish like guy said, will have a look when i get back from work.
ace
12 July 2009, 16:10 »
part numbers for the scuttle
W1H2 819 416 CB 41 DEFLECTOR £23.04 +VAT
W1H2 819 415 BB 41 WATER DEFLECTOR £32.54 +VAT
VR6-Joe
12 July 2009, 16:25 »
If this is the actual plastic scuttle panel cover thingy you're on about then I'll check the condition of the one on the TDI..
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Mikester
Forum addict
Civic Type R
Reply #6 on:
12 July 2009, 17:49 »
Cheers ace. So both of those parts are needed? If so I might get it new from dealer, along with having a new screen fitted I reckon. Cheers
ace
Reply #7 on:
12 July 2009, 18:46 »
yeah basically its the left and right side of the scuttle.
Mikester
Forum addict
Civic Type R
Reply #8 on:
12 July 2009, 21:56 »
Guy
Forum addict
Reply #9 on:
12 July 2009, 23:20 »
as said - both parts are needed
check to see if it comes with the clips too... like overgrown plastic screws... don't put old faded ones in with your new scuttle panel
while you are there check your wiper nut covers and replace them at the same time if they have gone grey... cost is minimal but they won't stand out then against the nice black panel
Golf mk3
hardmonkeys
