Author Topic: customising a standard factory fitted air box ( is it poss to do so?????)  (Read 7616 times)
Offline axewielder
  • 95 dragon 8v
apparentley the cold air thing isnt quite the same with diesels but more air always helps
heard this from a diesel expert on ukmkivs
Offline MK3TDi1996
I've uprated the nozzles, running powerplus Sprint 520's now, fratelli - the real deal! - or at least will be when I get my injectors back on monday :p
I've read (and it of course makes sense) that when uprating the nozzles, among other things it is definately worth increasing cold air to the system to compensate for the added fuel...
Offline MK3TDi1996
here' the pictures of my air box.... - 1.9TDi AHU
Offline Ess_Three
Doesn't look to be too much wrong with that...
I'd leave the lid alone as there is already a nice smooth duct to get the air out.
For the base, maybe just work out a way of getting more air in. Bigger inlet?
Get rid of the angled inlet with the restriction at the inlet...and get a bigger inlet in there.
That's about all you can do. Seems to be a pretty good design as standard.
..but gaining motorcycles.
Offline tweed
I took everything out of mine and took the standard air feed off. I bought a new 60mm air feed and put one end in the hole and the other end under the left side of the headlight right up close to the grill.
Offline MK3TDi1996
is it worth cutting the tubes away from the inside so the air goes straight in ie; not channelled
Offline Ess_Three
No, I wouldn't.
Fine it it's a restriction...but that looks to be parallel, with a flared end...which should air airflow out of the airbox.
I'd leave it, personally.
Look at the inlet though...try to get a bigger, coil air feed in there...from as close to the front of the car as you can.
locin78
Offline robz
hey, just to bring this thread back to lifa... again. lol
what dremel bit did you use?
i dont have a dremmel but obviously have a drill, is there an equivelant bit i could use to do the job properly?
seriously looking at doing this soon!
also is there a limit on what size in-let hole ya have, i know ess said that he had a 3" speaker port there, any bigger worth it?
and finally im going to feed cold air from the bottom of the front bumper, anything i should be considering before i go in head first?!
cheers!
Offline VR6-Joe
I personally wouldn't have a cold air feed from the bottom of the bumper, think of the crap that's going to go into it.
Water, bugs, stones, you name it, it'll end up in your air filter..
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
