Author Topic: VAGCOM Help  (Read 1604 times)
Offline pridders
  • Pearl Black 5 Door DSG GTI 05
VAGCOM Help
« on: 08 July 2009, 21:11 »
Hi All,
I need some help both the EPC and the exhaust light are on  :sick: and I need to know what is up. Should I take it to VW straight away or can anyone with a VAGCOM in reading/slough area help?
Any suggestions greatly received, getting a little worried...
Offline AlanD
  • MK5 2.0T 16v
Re: VAGCOM Help
« Reply #1 on: 09 July 2009, 10:39 »
If there is no one local look for a VAG specialist garage in your area and take it to them for a diagnostics. VW will pull your pants down on price.
Offline dan_apps
  • too low for british roads!
Re: VAGCOM Help
« Reply #2 on: 09 July 2009, 10:44 »
try here
http://www.golfgtiforum.co.uk/index.php?board=73.0
top stickie user locations or create a new post and someone should help you out for a pint or 2! :smiley:
Offline davegixer
Re: VAGCOM Help
« Reply #3 on: 10 July 2009, 11:20 »
Have you had any joy?
I had exactly the same lights on mine (and still have in fact, but it doesn't effect the drive aledgedly).
It is a memory fault in the ECU in my case, which means a new ECU (£££ouch). Apparently only VW can fit new ECU's as they need to be online to reprogram keys etc??? Not sure if that's the case, I'll do some digging.
Fingers crossed yours is a cheaper fix bud.
2017 GTI Clubsport Edition 40 #670
Carbon Grey Metallic, Black Roof, DSG, Leather, 19" Brescias, I'm in love with a car, help me.
Offline bertmort8
  • 2.0gt fsi
Re: VAGCOM Help
« Reply #4 on: 10 July 2009, 11:30 »
i ahd the epc light coming on along with traction control, when i saw the epc light on tho it cut all power to the car but didnt cut out
ended up being throttle bodies
wants a gt tdi
