Author Topic: Hottuning coilover problem.HELP PLEASE  (Read 1170 times)
Offline chrisj
« on: 08 July 2009, 15:38 »
Basically the star bit in the middle of the bit that comes into the engine bay has been rounded and you can no longer turn the nut on the outside so they aren't tight enough. Does anyone have any suggestions how to fix this because it isn't tighetning all the way and its causing problems.thanks
R Tech stage 1 AUM, Pipercross panel filter, forge 007p, Santa Monica's,Lowered 35mm Jamex Shocks and springs, Milltek Exhaust, mk5 rear wiper
Offline Waffs1984
  • Spacers are for chumps...
Re: Hottuning coilover problem.HELP PLEASE
« Reply #1 on: 08 July 2009, 15:48 »
Your going to struggle tbh mate if its the bit i think you mean - can you not get a set of mole grips around the shaft of the shock (using a rag for protection)?
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline chrisj
« Reply #2 on: 08 July 2009, 15:52 »
Knowing my bloody luck it is the bit your thinking?Would a mole grips actually be able to hold the shock though?Do they sell the coilovers as a set only does anyone know?
Offline linz
  • vee-dub
« Reply #3 on: 09 July 2009, 09:15 »
i hae them also and yh think they can only be bought in a set but as you should no they are prety cheap
Offline Waffs1984
« Reply #4 on: 09 July 2009, 10:33 »
Well i have used this method to tighten the strut top nuts on normal shocks before, but i don't know if you will be able to get access with coilies?
Failing that the only other thing i can think of is to weld something onto the top of the strut to hold it steady whilst you undo the nut? Of course the shock is then deffo scrap metal...  :sad:
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #5 on: 09 July 2009, 18:04 »
best way would be to get a windy gun on the nut, thats how i tightened mine up.
i have one good coilover from ones fitted to my old golf. the other had broken seal and leaked. think its a Jamex coilover.
Offline chrisj
« Reply #6 on: 09 July 2009, 18:21 »
Me and my mate done this today, by putting a mole grips around the shock. All sorted now thank god. :smiley: Did find out by one coilover and it was £89 delivered in case someone ever needs one
