Author Topic: can anyone verify kent gs23h cam duration?  (Read 2003 times)
Offline Khare
  • The bear that khares
« on: 07 July 2009, 16:24 »
276 or 285?
Bought via internet marked as a 276 cam, got it through and on the manual that it came with says its a 285. Which ever the two, it works wonders  :laugh:
Offline Adam
Re: can anyone verify kent gs23h cam duration?
« Reply #1 on: 07 July 2009, 16:30 »
276 or 285?
Have you fitted it?
Down Hill From Here.
Offline Khare
« Reply #2 on: 07 July 2009, 16:36 »
yup. fitted it yesterday evening dude  :smiley:
Offline Horney
« Reply #3 on: 07 July 2009, 16:39 »
It should have been stamped somewhere but a bit late now if you've fitted it!
nick
Offline Khare
« Reply #4 on: 07 July 2009, 16:40 »
nick
good point!  :grin:
dam  :sad:
« Reply #5 on: 07 July 2009, 16:42 »
It will be stamped on the end.
However
Application Power Band Cam Lift(mm) Valve Lift(mm) Duration Timing Full Lift VC (mm) LTDC
Sports ' R ' 2500-7000 11.53 11.53 285 Deg  33/72 72/33 110 Deg  0.00 I 1.98mm
http://www.kentcams.com/
Offline Khare
« Reply #6 on: 07 July 2009, 16:44 »
However
nice one. perfect dude  :wink:
Offline Horney
« Reply #7 on: 07 July 2009, 16:45 »
How does it idle? Nice and lumpy?
nick
Offline Khare
« Reply #8 on: 07 July 2009, 16:54 »
nick
yup, very lumpy! Love it!
Below about 3000rpm theres not much, but when 3000rpm kicks in its like vtec (sounds like it too)! it just pulls all the way to the limiter at over 6000rpm!
Offline Adam
« Reply #9 on: 07 July 2009, 17:23 »
Do a write up please!
