Author Topic: water pump and the oil pump on the 1.8t  (Read 1642 times)
Offline mac456
« on: 03 July 2009, 11:16 »
will it be done as part of the service?
if i buy one that has no evidence of these parts being change should i be worried?
Offline Rhyso
Re: water pump and the oil pump on the 1.8t
« Reply #1 on: 03 July 2009, 11:23 »
nope
you have to specify them to be done - oil pump won't need doing
water pump should be done at the same time as the cambelt otherwise you'll have 2 lots of labour charges
Offline mac456
« Reply #2 on: 03 July 2009, 11:42 »
thanks for the info,
apperently the car im going to see has had its cambelt changed twice so if the water pump has been changed it will be evident with the reciepts etc??
and if it hasn't is it a job that we need doing asap?
« Last Edit: 03 July 2009, 11:44 by mac456 »
Offline Rhyso
« Reply #3 on: 03 July 2009, 11:54 »
depends on the mileage - in theory the water pump should be a fit and forget item but it isn't as a few people on here will tell you  :sad:
any idea how long until the next cambelt service is due?? whats the current mileage on the car
Offline mac456
« Reply #4 on: 03 July 2009, 11:57 »
no idea when the next ones due, hopefully going to view it this weekend.
its done 108000. last thing i need at the min is it failing on me. tempted to get the 1.8 non turbo (but i know i will end up regretting it in the future)
Offline Rhyso
« Reply #5 on: 03 July 2009, 12:00 »
if its been done twice then chances are the cambelt isn't due for another 30K or so.
Its an item which you can't be 100% sure is going to be ok  :sad:
and deffo plump for the 1.8T - few quid on a remap; job done :afro:
although i'd go for a TDI myself  :grin: :grin:
Offline mac456
« Reply #6 on: 03 July 2009, 12:05 »
cool ;-)
if the water pump is going, are there any ways that you can tell before it completly fails?
and if i do go for this gti and there is no sign of the water pump being changed, should i get it done asap or wait till the cambelt will need doing next and get them both done at the same time?
thanks for your info as well matey
Offline Rhyso
« Reply #7 on: 03 July 2009, 12:15 »
no way to tell unfortunately - just keep a close eye on the temperature gauge - if it starts overheating pull over immediately and switch off the engine  :smiley:
personally i'd wait - no point forking out money for something that might never fail  :smiley:
Offline mac456
« Reply #8 on: 03 July 2009, 15:51 »
thanks matey,
dont suppose you know if any of these problems come with the tdi engine?
what sort of prices do the tdi 110 and 130 come under? 98/99/2000/2001?
Offline Rhyso
« Reply #9 on: 03 July 2009, 15:54 »
thanks matey,
you don't hear of as many TDI's suffering water pump failure - mine lasted 100K and was still going strong although i had it replaced when i had the cambelt done
range from 2K to 4-5k
130's were only available from middle of 2001 onwards though
