Author Topic: 1.4 to 1.6 16v - (can a 1.4 be rebuilt?)  (Read 3463 times)
Offline bondbill2k2
« on: 03 July 2009, 00:23 »
Found a 1.6 16v for sale locally, what parts would need changing to do the swap?
Gearbox?Radiator?ECU?Throttle body? etc..
« Last Edit: 03 July 2009, 09:48 by bondbill2k2 »
Offline tg1
Re: 1.4 to 1.6 16v
« Reply #1 on: 03 July 2009, 08:35 »
tbh i wouldn't bother just swapping up one engine size, i'd start saving for a 20vt conversion if i was you
i've no idea what you'd need i guess the box, and loom would be pretty much the same though
Offline bobbarley
  • I'm kind of a big deal...
Re: 1.4 to 1.6 16v
« Reply #2 on: 03 July 2009, 08:37 »
I thought the same.  for the tim, effort and cash involved, I wouldn't see the point.  It isn't going to be that much faster anyway.  Save your pennies toward a 1.8T :afro:
Re: 1.4 to 1.6 16v
« Reply #3 on: 03 July 2009, 08:41 »
I don't think you would make enough gain to make it worthwhile to be honest.
Offline linz
  • vee-dub
Re: 1.4 to 1.6 16v
« Reply #4 on: 03 July 2009, 09:36 »
seems a completely pointless conersion if u ask me
Offline Rhyso
Re: 1.4 to 1.6 16v
« Reply #5 on: 03 July 2009, 09:37 »
is the 1.6 a complete car??
why not buy it, transfer your bits over and then sell yours - far easier than swapping everything around
just be careful as to what gearbox is in it - they tend to be a bit choclatey  :lipsrsealed:
Offline bondbill2k2
Re: 1.4 to 1.6 16v
« Reply #6 on: 03 July 2009, 09:44 »
Reason for it is insurance wont even give me a quote on a 1.8T or anything larger.
And the 1.4 piston rings are gone thats in it atm.
Ive been told (by ukmk4 forum) you CANNOT replace them on a 1.4 as the aluminium block warps if you loosen the crank OR the bearing cap bolts.
If you even loosen them then the bearing clearence will be out and can cause serious damage. Am i right in saying the bearing cap bolts are those which hold the piston to the crank?
Quote
""if the bearing cap bolts are loosened the cylinder block must be replaced complete with crankshaft""
:huh:
This sounds like the stupidest engine design ever!
I've had two good quotes off engine rebuild companys on the engine, so i was planning on that but now im told you cannot rebuild them or even replace piston rings  :lipsrsealed:
Re: 1.4 to 1.6 16v - (can a 1.4 be rebuilt?)
« Reply #7 on: 03 July 2009, 10:01 »
Ford Zetec SE 1.4 and 1.6 is the same design, just designed to do 100k and then be thrown away, crazy.
Offline bondbill2k2
« Reply #8 on: 03 July 2009, 12:36 »
Called several engine rebuild company and took the printout with warning to a couple, all said its nothing to worry about and only something VW use to make people spend £2000+ with them for a new engine  on every 1.4 pretty much, as they will go almost always go at some point (piston rings, valves, usual probs)
One of them had a 1.4 16v mk4 same engine code as mine they had jst rebuilt in a car running while was there. Also comes with a couple years guarantee
Offline Mk1Macca
Re: 1.4 to 1.6 16v
« Reply #9 on: 03 July 2009, 12:39 »
Try getting them to quote when you utter the words 'I changed the engine'...
Much easier to just buy a new car  :smiley:
