Author Topic: please help  (Read 1589 times)
Offline chezney55
please help
« on: 02 July 2009, 17:51 »
8v gti still cutting and heasiting out changed the hall sender cleaned the throttle body. put new plugs on am pissed off with it now. its getting worse. cheers chez
Offline Adam
Re: please help
« Reply #1 on: 02 July 2009, 18:06 »
Checked the relays?
Air leak?
Down Hill From Here.
Offline chezney55
Re: please help
« Reply #2 on: 02 July 2009, 18:10 »
done every thing that i have been advised 2 do off here :undecided:
Offline Adam
Re: please help
« Reply #3 on: 02 July 2009, 18:11 »
So you have changed the relays?
Got it scaned with vag com?
Offline chezney55
Re: please help
« Reply #4 on: 02 July 2009, 18:18 »
yes done that no faults!!! its totally pisseing me off :angry:
Offline Len
Re: please help
« Reply #5 on: 02 July 2009, 20:33 »
Checked the dizzy cap for cracks? Also rotor arm.
www.sas.org.uk
www.the-ace.org.uk
Offline alanspain
Re: please help
« Reply #6 on: 02 July 2009, 21:03 »
Temputure control valve, 21 pound euro part, only a two min job mine was the same mate, its a dream now apart from the cam belt going and doing four valves lol should be fixed by weekend fingers crossed
Offline karl29
Re: please help
« Reply #7 on: 02 July 2009, 21:40 »
i had a similar problem with mine my timing was way out and wouldnt rev past 5000 the mark on my bottom pulley is out when its aligned if you get what i mean so timed it up by the mark on the flywheel now its the best its ever been no hesitating or cutting out may be the same problem with yours you never know it may be worth checking
Offline Lakeside
  • wassuppp
Re: please help
« Reply #8 on: 03 July 2009, 14:42 »
Have you replaced the crank sensor.?
Offline chezney55
Re: please help
« Reply #9 on: 03 July 2009, 18:15 »
yes still no joy :angry: :sad:
