Author Topic: high vac on tickover? i have searched, just need some clarification  (Read 1336 times)
Offline Dempsey
  • Fabia vRS SE, Blue, number 553
as above. i have done some searching, and have found out its not a vac leak.....
some people have said it could be a faulty gauge, so jus need some clarification....
i have installed my boost gauge today, and just have a few questions.
on tickover, it sits at around 30.
i recently installed a new recirculator valve too, the car seems to drive the same, just the reading on the boost gauge worries me.
Is it a possibility of a faulty gauge, or is it possibly due to the needle not sitting at 0?
its an "Auto Gauge" Boost gauge from halfords.
any help would be appreciated.
Audi TT Polished Comps with 205/40/17 tyres for sale £400 - http://www.golfgtiforum.co.uk/index.php?topic=142136.0
jamie16v
i have one of these guages too and to be honest i think it just rests where i wants to on vac.. basically its not all that accurate..
though mine never vacs at 30.   -22 psi is probably the most it will go to..
Offline Dempsey
ah right, ok.
might make a difference if i zero my needle then?
Offline jonnyturbo
Gauge on tick over should be at minus 20 then when you put your foot down you will create the vacuum then you will get your reading in plus
Offline Dempsey
mine is on 30 though?
so is that bad?
Offline Grand Master Patch
so is that bad?
The question we need to ask is what does the gauge sit at without the engine turned on?
Offline Dempsey
the gauge sits at around just above 10 on vac, it doesnt sit at 0.
would i see a more accurate reading if i sat the needle at 0?
YES :grin:
Take it back and swap it for one that works.
