Author Topic: ECU access  (Read 1415 times)
Offline paul73
ECU access
« on: 01 July 2009, 19:32 »
Hi,
Need to change my ECU as VAG com is showing a ECU failure and it is always in safe mode.
How do you get to it?
What do you have to do to change it please?
VAG com would think that it has failed because it is safe mode would it??
Thanks
Paul
Offline Adam
Re: ECU access
« Reply #1 on: 01 July 2009, 19:33 »
Reset the ECU by disconnecting the battery for 30 mins. Try that.
Down Hill From Here.
Offline paul73
Re: ECU access
« Reply #2 on: 01 July 2009, 19:42 »
Tried that numerous times thanks
Offline Mikester
  • Civic Type R
Re: ECU access
« Reply #3 on: 01 July 2009, 20:39 »
Its located under the scuttle panel.
Offline admc6
Re: ECU access
« Reply #4 on: 01 July 2009, 20:57 »
Its really easy to get out, may take you as long as two mins
Offline AudiA8Quattro
Re: ECU access
« Reply #5 on: 01 July 2009, 21:52 »
Take your time.
If i remember right, some off those clips on the scuttle were f**king annoyingly stuck!  :laugh:
Try not to break anything, like i did  :embarassed:
Offline Mikester
  • Civic Type R
Re: ECU access
« Reply #6 on: 01 July 2009, 22:48 »
You are not alone
Offline paul73
Re: ECU access
« Reply #7 on: 02 July 2009, 23:53 »
what is the scuttle panel?
Re: ECU access
« Reply #8 on: 02 July 2009, 23:57 »
It is the panel that runs along the bottom of the windscreen,
Offline Len
Re: ECU access
« Reply #9 on: 03 July 2009, 09:29 »
Its the plastic panel between engine bay and windscreen where wipers come through.
Lift bonnet and take off rubber strip.
You want the right side (nearside) half. Once the plastic studs are out you just have to watch the end bits around the bonnet hinge as that bit usually breaks!
www.sas.org.uk
www.the-ace.org.uk
