Author Topic: SoundillusioN - the re-united mk1!  (Read 224254 times)
Offline SoundillusioN
Re: SoundillusioN - the re-united mk1!
« Reply #40 on: 16 January 2011, 19:58 »
Also last night i managed to trace my boot leak! was a broken lens where sombody had reveresed into the car when stored.  I had another set of OEMs to replace the ones i smoked.  put them on and all good.  Also after the rewire i had a disco on the same side, you know , when the indicators and lights are on, everything kinda does a dull flash together on that side! turned out to be a loose connection.
« Reply #41 on: 16 January 2011, 19:59 »
Ok, so fitted the rear collies, i found it more of a pain than the front, getting the old ones out was nowhere near as easy as getting the new ones in!  all mounts have had a smidge of LM grease on them to help protect the turrets (since they are still mint) and to avoid any squeeky noises appearing)
Taking short cuts!  :sad: havent given the inner arches the same TLC as I did the front as I am trying to get it road worthy quickly now... going to have to do the attention to detail stuff after i've MOT'd it.
Nicely mounted with pollys  :smiley:
« Reply #42 on: 16 January 2011, 20:00 »
Couple of shots of the car...
The rears are fully wound all the way up, they are as high as they will go and the car looks slightly lower than before... confused???
« Reply #43 on: 16 January 2011, 20:01 »
Have to start getting organised so for my benifit made the following lists.... If anyone can help source anything i'm missing though, that would be great!  :smiley:
To Source
All wiring looms (Engine, Interior/Dash, Lights)
Bonnet
Front Bumper
N/S Wing
Front Indicators
Front side light bulb holders
Headlight bulb retaining clip
Rear Lights
Front Seats
Gear Linkage Kit
MK2 16v 256mm Vented Grooved/Drilled Discs
MK2 16v Front Brake Pads
New rear drums & Shoes
New Handbrake cables
Wheel bearings x4
15" BBS RA (Sportlines) x4
Late MK1 cabby Twin light Grille
Battery
Coil
Coilovers
Front Suspension Top Mounts
Rear Suspension Top Mounts
New Fuel Filter
Door Lock Pin
Headlight Bulbs
Spotlight Bulbs
Rear Twin Filament Bulbs
Windscreen Scuttle Repair Panel (hopfully picking one up on Thursday!)
Windscreen Seal
Window Winders
Twin Tone Horns
Front Wipers
To Do
Strip out interior
Remove all wiring
Paint engine bay
Strip and paint cam cover and cam belt cover
Remove BBS body kit
Full Rust Hunt and repair (in progress)
Strip inner wings, paint/waxoyl (fronts done)
Strip Sills and Seams Paint/Waxoyl (in progress)
Rewire car
Make and fit high power headlight/spots loom with relays
Fix Fuel gauge sender
Fault find MFA and fix if possible
No instrument cluster lights, fix
Remove and replace all gear linkages (done but needs to be aligned!)
Replace radiator
Clean out cooling system, fill with X Stream G30
Multiple engine flushes, new oil filter and fill with semi-synthetic
Fit later style cabby grille
Fit new bumper
Fit new 10 LED front indicators
Fit horns
Refurb wheels
Fit new tyres
Fit new wheels
Remove braking system
Replace rear drums pads and wheel bearings
Service Corrado Front Callipers
Replace front discs vented drilled/grooved 256mm and pads
Fix boot leak
Replace rear lights
Fit coilovers
Prep and paint and interior
Sound proof interior
Wash carpets and refit
Fit Seats
Fit window winders
Fit Front Wipers
Remove windscreen
Repair leak behind window rubber with new scuttle panel
Prep and paint BBS body kit (Satin Black)
Prep and paint body and panels (Satin Black)
Theres bound to be more... I need to get the vitals done and MOT'd by 21st September!!!  :embarassed:
« Reply #44 on: 05 February 2011, 02:21 »
Well i hit a stroke of luck, the dude that i bought my £10 bumper from was kind enough to cut this off his breaker for me:
dont need all of it, just a bit for the inch of crisps behind the windscreen rubber... circled area is the problem area on mine... he gave me more than enough to play with for another tidy some of......... £10!  :smiley:
« Reply #45 on: 05 February 2011, 02:22 »
not that interesting but I just won a brand new front bumper for £8.50!
Thats 3 ive bought now!  :grin:
« Reply #46 on: 05 February 2011, 02:23 »
Just ordered the following in time for my week booked off work!:
256mm Mintex MK2 16v discs and pads
2x New Raceland GTBs with new rails and gliders.
« Reply #47 on: 05 February 2011, 02:24 »
Just bought this as i have now found that mine is leaking!
Heater Valve
« Reply #48 on: 05 February 2011, 02:25 »
Ok, so have had a week off work to try and get as much done to the car as poss (rained quite a bit!  :angry: ).. gonna post whats been going on.
Seats arrived....
Heres one next to my old Drivers side heated Recaro
it had to go, it was fooked and when the heat was on it smelt bad  :laugh:
Carpets aren't in yet but wanted to see how at least one of them was like fitted.  was a pain to get them setup right with the new brackets...  on the shortest setup i think the seats are still too high, i'm pretty tall and with these in, my head only just clears the roof!.. may have to get something welded in at a later date, i'll post a pick of one fitted later as i havent got one.
(more coming very shortly)
« Reply #49 on: 05 February 2011, 02:28 »
Wasnt happy with the paint on the new front panel, so stripped it off and repainted it!
