Author Topic: Swapping Heads!!  (Read 948 times)
Offline Petec82
  • It may be just an 8v but it's my 8v!
Swapping Heads!!
« on: 28 June 2009, 15:13 »
Hey all!  :smiley:
I was wondering if the cylinder heads from the various 2.0 8v engines were interchangeable?
I can see no reason myself as to why say an ady wouldnt fit an agg or visa versa but I have noticed that there are at least two different inlet manifolds accross the range. I wasn't sure if this would effect compatibility.  :undecided:
So can they swap?
Pete  :smiley:
"What do you say we kill some evil sons of b*tches and we raise a little hell!"
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Swapping Heads!!
« Reply #1 on: 28 June 2009, 19:15 »
the head should be ok but if the inlet mani is diffrent you would need to use the correct one, and remember than each engine had a diffrent injection system which requires the correct inlet plenum chamber etc.. so that would need to match up.   Otherwise i think they fit ok.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Adam
« Reply #2 on: 28 June 2009, 22:42 »
Also cold you put a 16V head on a 8v? I heard it somewere a while back on ED38.
Down Hill From Here.
« Reply #3 on: 28 June 2009, 23:24 »
I would think no, the basic engine has a lot of changes.
Offline Khare
  • The bear that khares
« Reply #4 on: 28 June 2009, 23:30 »
for starter the valves would hit the pistons. Would need notched pistons like the 16v has.
Offline danny_p
« Reply #5 on: 29 June 2009, 00:43 »
you need a turbo
all the VW's have gone bar 1.
