Author Topic: my 16v is idling at 1400 and 2000rpm  (Read 2424 times)
Offline tweed
« on: 24 June 2009, 17:22 »
Ok I took all the induction off, so I could get to my master cylinder. I unpluged one sensor that comes of a breather pipe (i think) and I unpluged the one that is on the airbox. yesterday I had to move the car on the drive, left everything unpluged and it did idle high then. I knew it would, but today I modified the air box. I took the trumpet out, also the part that is in the bottom of the airbox and gave it a cold air feed.( using the standard air feed hole) I connected and pluged everything back together to see if it was more responsive. Well this is the problem, I start the car and it idles at 1400rpm, if I rev it it settles to 2000/1800 rpm and thats when it's warm too.
What do you think is happening? to much air which I doubt.
Or how do I fix this problem? I have disconnected the battery hoping this will reset it.
Thank you for any help
Offline Paul86S2
Re: my 16v is idling at 1400 and 2000rpm
« Reply #1 on: 24 June 2009, 18:04 »
What did you do with the vacuum pipe from the throttle body to the airbox?
You really need to block this off. If it is left open it will cause a high idle like you describe.
Paul
Offline tweed
« Reply #2 on: 24 June 2009, 18:12 »
Paul
I've plugged it back in mate. So should I take it out and block it off at the throttle body?
Offline Pete Taylor
« Reply #3 on: 24 June 2009, 19:57 »
Check the thick breather behind the throttle body that runs to the carbon cannister, make sure it's pushed in properly, that'll be the jobbie
Offline Paul86S2
« Reply #4 on: 24 June 2009, 20:38 »
Paul
Depends how much of the diverter valve you removed. Just stick a bolt in the end of the pipe and see if that makes a difference. Also as Pete says check the big black one that goes to the carbon cannister.
Paul
Offline Len
« Reply #5 on: 24 June 2009, 20:40 »
Check all the breather hoses, I had it with TB to ECU!
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #6 on: 24 June 2009, 22:29 »
Thanks lads I will try tomo, hope that is the problem. It's got to be simple because it was fine. :undecided:
Offline tweed
« Reply #7 on: 25 June 2009, 10:45 »
right evrything is pluged in, all breathers are in. I'm stumped! I did unplug the sensor that is on the black part that is bolted to the strut (rubber mounted) and that made no difference. Maybe I damaged it some how. would that make it rev? well I'm going to fit my new master cylinder then crack on with it some more.
« Last Edit: 25 June 2009, 10:48 by tweed »
Offline Len
« Reply #8 on: 25 June 2009, 17:00 »
Have you checked all the breather hoses? I mean taken them off and blown throug them to check they aint blocked?
How I found my fault!
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #9 on: 26 June 2009, 15:18 »
All fixed. I was being a f**king dumb gimp!
