Author Topic: Pollen Filter/ECU Cover  (Read 1862 times)
Offline Len
« on: 20 August 2004, 11:56 »
Seen similar posts about this - but my query is a bit different.
I broke my cover when getting out the ECU (before i joined here) and althought i havent had the damp in car like others, the panel now doesnt fit properly, so i'm gonna get a new one.
I am worried that i may break the new one during fitting and wonder if anyone has done this yet?
The tricky bit is around the bonnet hinge and i am wondering if it would be wise to take off the other half first?
Any advice welcome
www.sas.org.uk
www.the-ace.org.uk
Offline jte
Re: Pollen Filter/ECU Cover
« Reply #1 on: 20 August 2004, 13:48 »
I found refitting the cover a bit of a challenge when i replaced my pollen filter.
It is fiddly round the hinge, i just kept wiggling it about till i found the right angle.
I would suggest having a few practices with the broken one to see exactly how it fits, then you should be able to slide the new one in no problems.
A VR6 isn't a way of life, it's just a car.
Offline Len
« Reply #2 on: 20 August 2004, 13:58 »
Yea fiddly as f**k!
I broke it the first time i took it out to have the ECU checked. Had it out about 5 times since. to put ECU back in, then to check pollen filter, then coz i wasnt gettin much air flow thru the fan/vents, then to change the pollen filter coz it had got wet, then again to try and get a better fit!
And it aint got any easier each time.
Local dealer aint got one so i gotta to Oxford for one. bummer!
www.sas.org.uk
www.the-ace.org.uk
Offline jte
« Reply #3 on: 20 August 2004, 15:24 »
Ask vw to fit it!
I'm sure if ask nicely they will fit it in the car park for you.
Might be an idea to send a woman in with it.
Offline Len
« Reply #4 on: 20 August 2004, 15:45 »
Did get a nice exploded view of all the vents and dash components of em tho.
If anyone wants one i can scan it sometime over the weekend and email it.
www.sas.org.uk
www.the-ace.org.uk
