Author Topic: Spot the Problem - GGGRRRRRrrrrrrrrrr  (Read 3070 times)
Offline Ben Lessani
Re: Spot the Problem - GGGRRRRRrrrrrrrrrr
« Reply #20 on: 21 June 2009, 17:17 »
You get embarrassed driving round with a car that sounds like a ford, worse case the cam gets damaged from constantly slapping the tappet heads.
Offline danny_p
« Reply #21 on: 21 June 2009, 20:19 »
remove camshafts,  beat person who reconditioned head round the head with camshafts.   then find and kill a mk3 16v so it can be used as an organ donor
all the VW's have gone bar 1.
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #22 on: 22 June 2009, 08:34 »
You say you have another engine?? This is what I would do.
Remove the oil filter from the engine that is presently in the car and carefully cut it open. Look at the filter element for signs of metal. White metal, as long as there is not much, would probably be from the head where the mismatched caps have worn. Any ferrous metal, which is attracted by a magnet means that something may have gone through the the oil pump.
If all is well, then remove the head from your spare engine and give it a bit of a service, ie, lap the valves in, fit new valve guide seals and give it a decoke. If funds can stretch that far, give the face of the head a light skim, purely to reface it and take out any deformations rather than to give it any performance gains.
Then fit to existing engine and reap the benefits of your labours. If you need a helping hand, P.M me. But there is no need to put the car into a garage and hand over money when help is at hand.
This need only cost you a head gasket set, and some time. If you can, a new set of followers and a reskim would be beneficial to round off a decent job. :wink:
Offline JC
  • Back in the North.
« Reply #23 on: 22 June 2009, 09:33 »
unfortunatly i have fcuked my back tinkering DPB. I am having enough trouble walking let alone owt else  :cry:
all this and it needs a the suspension addressing too as the front HASNT settled.
Offline Diamond Hell
  • Opinions я Us
« Reply #24 on: 22 June 2009, 11:38 »
I think I still have the Toledo 2.0 Sport springs lying around at mine.  These were on my car until a couple of weeks ago.
If your front end's too high, they might be a (free) solution.
If you'd cracked into this a few weeks ago I could have helped more..... bit screwed at the moment though  :sad:
Offline JC
« Reply #25 on: 22 June 2009, 12:26 »
I know DH, she will be BACK DOWN by tonight ( pain killers are poping down nicely ) so part exing might be an option  :lipsrsealed: v cough r cough 6
  • Opinions я Us
« Reply #26 on: 22 June 2009, 13:07 »
Well you're an old fart, so the descent into old man's cars can't come soon enough, really, can it?
Offline JC
« Reply #27 on: 22 June 2009, 19:13 »
well i had an listening jobby onto the top of the engine, a METALIC sound is a lot more prominent above the " perhaps " incorrectly fitted camcovers.
then someone mentioned Oilways, and are they beng fed correctly, or are the covers seated properly,
so, wednesday nights job is " swap them over "  :shocked:
Offline Ben Lessani
« Reply #28 on: 22 June 2009, 19:45 »
Plastigauge first, swap later
