Author Topic: central locking problem  (Read 1153 times)
Offline Guy
« on: 20 June 2009, 20:13 »
key rotates 'loosly' in drivers door lock - will not activate central locking
key turns lock in passenger door but will not activate central locking (it did do once apparently according to the mrs)
once rear door pins are pulled up to unlock them they reactivate the c/l pump and re-lock themselves
what to check, what to change etc pls?
Offline Guy
Re: central locking problem
« Reply #1 on: 26 June 2009, 00:30 »
*bump* one of you must know...
btw.. barrel has completely come out of the lock now!
« Reply #2 on: 26 June 2009, 09:08 »
Try another door handle, it might have worn on the end.
« Reply #3 on: 26 June 2009, 10:02 »
swap pasenger lock bits to driver side. not sure if its same on mk3, but on mk2 the factory cl will only trigger from driver side.
Offline troublestarter
« Reply #4 on: 26 June 2009, 10:27 »
mk3 central locing is multipoint so can be activated from both front doors
it relocks itself be cause the microswitch in each door that controls the pump is not being activated when just pulling up a pin
guy if i have time on monday after fitting your alarm and stereo i will have a look at it for you
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline Guy
« Reply #5 on: 26 June 2009, 12:24 »
 :smiley: :smiley: :smiley:
i'll make sure the car is available Ken as this is doing our head in!  :laugh:
Offline Guy
« Reply #6 on: 29 June 2009, 18:58 »
top man... swapped the handles! will replace with a blank rear handle... happy days!  :laugh:
