Author Topic: rattle problem  (Read 1714 times)
Offline gazpowells
rattle problem
« on: 19 June 2009, 21:41 »
hi
need some help with an annoying rattle please
I have coilovers fitted with new mounts but when driving slowly their is a rattle coming from the rear suspension
does anyone have any ideas what this could be?
thanks  :smiley:
Offline Adam
Re: rattle problem
« Reply #1 on: 19 June 2009, 23:29 »
Feel for you, I have a squeek and its driving me madddd......
Is it both sides? All the bolts done up properly?
Top mounts on the correct way?
Down Hill From Here.
Offline Grim_Reaper
  • warningz...i haz powaz
Re: rattle problem
« Reply #2 on: 19 June 2009, 23:31 »
you sure its not a peice of trim thats chaffing somewhere in the rear???
Offline Khare
  • The bear that khares
Re: rattle problem
« Reply #3 on: 19 June 2009, 23:34 »
I had the squeak on my mk2 dude, guess what? its the plate that splits the upper and the lower springs. I just sprayed a load of WD40 every so often and it shut it up  :smiley:
Re: rattle problem
« Reply #4 on: 20 June 2009, 00:07 »
A rattle from the rear will be the top mounts, mine was the same also worth checking your exhaust / axle beam clearance.
VW BUSH
Re: rattle problem
« Reply #5 on: 20 June 2009, 02:04 »
oh no untraceable squeek=Many window open driving over speedbumps turning the stereo down moments then thinking sod it and turning it back up again :grin:
Offline gazpowells
Re: rattle problem
« Reply #6 on: 20 June 2009, 07:52 »
thanks guys  :smiley:
top mounts have been replaced and the exhaust / axle beam clearance its ok
cant be any trim as the car is stripped  :smiley:
will get car up on ramps today and have a good look under her..  failing that will get suspension out, check all nuts and bolts are ok and will try oil on the springs
its making me crazy  :angry:
Re: rattle problem
« Reply #7 on: 20 June 2009, 08:02 »
Were the new rear top mounts genuine or aftermarket.
Offline gazpowells
Re: rattle problem
« Reply #8 on: 20 June 2009, 08:14 »
cheap aftermarket mounts from e-bay mate
Re: rattle problem
« Reply #9 on: 20 June 2009, 08:53 »
I had issue with the cheaper ones would start rattling after a week or so, try genuine ones they are not that more expensive.
